Question about RCA P52926 52" Rear Projection Television
Rca p52770eb wont come on sparks in the back about 2 inches from the power cord inside the tv
  • 65 Answers
On some of the RCA televisions, the Hi Volt transformer will go bad and make a sizzling or popping sound. Most often, it will smell burnt when this happens.
Posted on Aug 02, 2009
Where can i buy a new power cored for my 47 inch rca projector tv at
the cords are usually fairly generic, large three pin like a computer tower no problem. If a odd shaped one go looking by model number on the internet, the older the set the more generic the cord will be.
Sep 02, 2012 | Televison & Video
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
Power will not come on for a rca p52720lv tv>
Power will not come on for rca p52770EB tv. I used to hard time to turn it on. Now it is dead.
Sep 13, 2009 | RCA P52926 52" Rear Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
I need to replace the power cord
you will have to open up the back of the tv. This can be a very dangerous as there can be a lot of stored voltage inside even if its unplugged. If you choose to do it, look on the back of the circuit board for an empty connector that used to have the power cord. Sometimes they are soldered striaght in, Do you have a replacement? Also if there is some wire left you can splice the wires togeher without having to do any soldering.
Feb 03, 2009 | RCA 27F530T 27" TV
Power cord
you would need a qualified tv personal to re- insert the power chord
Jan 20, 2009 | RCA 27V530T 27" TV
Power cord came out
look for the fuse on the board closest to where the cord used to come out, you will probably see where it hooks up. it will be very close to the fuse.
Dec 19, 2008 | Televison & Video
TV Sparks inside case
I think I would turn it off and unplug it. You could get an estimate on reparing the power supply cord or whatever the problem is or the TV maybe ready for replacement.
Aug 16, 2008 | RCA 32V550T 32" TV
Rear Projection TV P52770EB
You could have a few problems . If the front display light flashes only it could be you need a new deflection module . Also the HV block may be bad with it . If you have no front display light when you turn it on it could be the above problem or the signal board could be bad . The signal board would cost the most to get repaired due to it costs more. You would need a meter to check certain testing points to confirm which module is bad . Or call around to see who has the cheapest rate on an estimate to check out your tv. deflection board and hv block est $250 to $300. Signal board $300 to $350. Maybe more if you had a service call if you could not take it to a repair shop. Good luck
Feb 29, 2008 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
142 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
