Question about Magellan Maestro 4040 GPS Receiver
We used our GPS on Sunday and it just froze on the same information on the screen,. The direction page came up and updated but the map part is frozen and is still frozen now is there a way to reset?
    President:
  • 1,111 Answers
The rest is the little pinhole on the left side, but this is a common problem on this model magellan, you need the latest update if you dont have it already. sadly if the update is interrupted or not done properly, it will be rendered useless and update reinstalled. you can get the update and manual here
good luck
Posted on Jul 18, 2009
Frozen screen with Garmin
Try resetting it, otherwise leave it on for over a week until it's completely flat then try again
Feb 01, 2014 | Garmin nuvi 1390T Car GPS Receiver
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
Magellan Roademate 5045 frozen on map screen. Is there any way of restarting it? There is no small hole for a reset button and I tried holding the power slider for ten seconds. No luck
I had exact same 'Magellan 5045 frozen' problem. Here is how I fixed it. Go to www.magellangps.com/contentmanager. Download and install Magellan Content Manager. Plug in your GPS. If content manager does not activate automatically, start it manually, like any other windows program or by right clicking on its icon. You will be asked to register your device and its serial number, etc.
After registering, if Content Manager fails to take you directly to the download location for your device, along the top of the Magellan web pages you will see a set of tabs, one of those is 'Support'. This is a pull-down menu. Select Manuals and Software update. This then takes you to their 'Support' web page. On the support web page, click on the 'Manuals and Software Downloads' button. This will take you to a page where you will be asked to select from four Download Categories. For the roadmate 5045 and similar gps intended to be used in an auto, select 'Magellan Vehicle Navigation'. This will take you to another page where you will have to select from three product series. For the 5045 series, select 'Roadmate Series'. This is another pulldown where you will have to select your product number, e.g., Roadmate 5045. This will finally take you to a page where you can select software and map updates. You will have to connect your Roadmate gps to your computer via USB and you will have to register. It is confusing because you will get incorrect and irrelevant statements like your device failed to register. It is somewhat quirky but if you follow the instructions and you have a wideband cable or FIOS internet connection, the upgrade to the software and the maps takes about 30 minutes. Do unplug your RoadMate from the USB unless asked to do so by the Content Manager program. After the software and maps update, the Roadmate 5045 worked like better than new for me.
Jan 06, 2011 | Magellan 5045 GPS Receiver
NEED UPDATED MAPS
Hi Some Sunday Markets Sell disks with maps for all types of GPS units try there.
May 10, 2010 | Tomtom ONE GPS Receiver
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
Frozen map screen
Try purchasing a new SD memory card (brand name) and installing the files there. Sometimes the manufacture sends cheap SD cards and the data is easily lost in damaged or poorly made SD cards. I have a EVESHAM 2007 and installed the files from the original CDto a new SD card and solved freezing and other problems resulting from poor data transmission from the cheap SD.
Also, try going online to the manufactureer's web site to see if they have downloads/ updates available there to replace the origianl install files that came with the unit. Always put on new brand new SD card.
Hope this helps
Feb 23, 2009 | GPS
Frozen screen on Magellan RoadMate 2200T
Press the button to turn it off but hold it for about 10 seconds. Let go and then press it to turn it on. This resets it.
May 22, 2008 | Magellan RoadMate 2200T GPS Receiver
I Would like to update my Garminc330. I have a glitch in the map (tells me address doesnot exist, when I know it does)
Hello mjs91411,
The Garmin maps updates page appears to be down at the time this is being posted, but the page to get updates for your GPS is https://my.garmin.com/maps/updates.htm.
You can also sign into the My Garmin page at https://my.garmin.com.
Best regards,
Ken
Go Ahead. Use Us.
May 20, 2008 | Garmin StreetPilot C330 GPS Receiver
Streetpilot c330 Frozen on.
take the face plate off of it, and to the right of the screen there is a reset button
May 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
224 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
