There shouldn't be a motor in the brush. The brush is powered by the suction on the hose. Check the suction on the hose. The vacuum itself might need to be cleaned. If the suction is a problem and you have cleaned the vacuum I would contact dyson support to see if they can replace your vacuum. http://www.dyson.com/support.aspx
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
SOURCE: Dyson Animal DC14 brush will not rotate. Removed
If this model takes a clutch then it is stripped and needs to be replaced.
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
SOURCE: DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
SOURCE: Dyson DC14 Brush Bar won't turn
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
