Question about Verizon Communications enV2 Cellular Phone
My phone doesnt read my memory card. It said that its not inserted when it is
  • 66 Answers
Check whether u have inserted in the right way..
Posted on Jul 17, 2009
  • 6 Answers
SOURCE: Memory problems Nokia N95
Bit of a long shot, but take the card out and clean the gold contacts with a pencil eraser (a hard eraser is best).
Make sure there are no bits of rubber on the contacts when you put the card back in :-)
Switch the phone off and push the cleaned card in and out a few times. Good luck.
Posted on Oct 30, 2007
Bajanguru
  • 7752 Answers
SOURCE: doesnt read memory card
go to menu/settings and security reset then enter 0000 and that will reset the phone or you can seek your manual for the that.
Posted on Dec 27, 2008
  • 5 Answers
SOURCE: my env2 wont read my memory card!
this also happened to my phone its not the memory card, its the phone...check if any of your front keyes on your keypad are broken too. Mine where and it was as if the memmory card didnt exist. If this happens you have a 1 year warranty with verizon and you can get a new env2 which is what i just did. they sent me a new one and it works perfectly.
Posted on Jul 03, 2009
shafykp750
  • 1070 Answers
SOURCE: when i insert memory card phone says format
Hello friend,
  • MMC might be Corrupted
  • Check by putting other MMC into your phone jack
  • If Phone jack is ok you have to Clear MMC
  • You can put it in to CARD READER through PC
  • and manually Format it
  • You are done
You are solved .....Enjoy....!!!!!!!!!!!!!!!!
If you helped this post Rate me.........
you can feel free contact me.......
Posted on Mar 29, 2010
suru1414
  • 194 Answers
SOURCE: i just had my phone
its a hardware fault
Posted on Feb 14, 2011
I inserted my memory card into the phone and nothing has shown up! Is there anything I must do to make my phone read it? Is there any settings that need to be set up?
switch off your mobile after inserting memory card.
if this doesnt work check whether you have put any password in memory card.......
Feb 18, 2011 | Eforcity For LG GT365 Neon Hard Case...
My cellphone dose not read memory card and i can't format it
maybe your memory card is damaged or corrupted... check it by inserting other memory card... if your phone CAN read other memory card it means that your memory card is damaged or corrupted... and if the other memory card you inserted and still the same problem persist that your phone thus not read memory card... maybe there is something wrong with your phone... it can't detect a memory card...
options:
- replace new memory card (if damaged)
- go to the cellphone technician and have that phone fix..
goodluck...
Feb 02, 2011 | Nokia 5130 Cellular Phone
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
My nokia 3110c always restart when my memory is inserted.. how can i solve this problem? but if i didnt insert my memory my phone doesnt restart..
It is obvious that the memory card you inserted into your phone is bad (it has virus) and that's why the phone keeps restarting.
Try inserting another memory card and let's see what happens.
Take care.
Nov 20, 2009 | Cell Phones
The phone doesn't read the card
insert a working micro sd card..if it doesnt detect the memory card.. the memory card slot of the main board pcb is defective
Jul 19, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Get Memory card not inserted
simply check the memory card through card reader if it works then u have to check the socket of phone where the card is to be inserted..
that one is causing problem...may be its pins are not propely being connected with the memory card..
if  the card doesnt work even with memory card reader then the card is faulty...or if u dont have memory card reader just put your memory card in another compatible phone to check..
or get another card and put it in your phone for checking..
hope it will fix the issue so dont forget to rate it...
Jul 06, 2009 | Nokia 5800 XpressMusic Smartphone
My env2 wont read my memory card!
Apr 11, 2009 | Verizon Communications enV2 Cellular Phone
Sidekick lx sd memory card error
The only way you can solve this problem is by calling tmobile & getting a new lx (free if you have insurance). I was having the same problem & thats the only thing that stopped the error message & i have all my pictures and themes back but now my music on my memory card doesnt show up on my lx. I'm still working on solving that issue.
Jan 12, 2009 | Samsung SCH-a930 Cellular Phone
After reformatting my fujitsu lifebook n5010 it doesnt read it.
Is the card reader built into the computer?
I know there are a few card readers out there having trouble reading 2 gig memory cards if the computer or card reader was built over 5 years ago.
If you have a data cable for your phone and software for the phone, your computer should be able to read it that way.
Nov 12, 2008 | PNY 2GB microSD Memory Card
Psp not reading memory card
Have you try other memory card ? If other card works then means your old memory card is broken. You need a new card !! In fact I sell cheap 4Gb memory card ...
Jul 28, 2007 | Sony PlayStation Portable (PSP) Console
Verizon Communications enV2 Cellular Phone Logo
144 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
