Question about Bionaire BCM6010 Humidifier
Bionaire Bcm630 Just bought the tower hunidifier. Base fills with water and overflows...any suggestions? the unit is brand new.
  • 4 more comments
  • Anonymous Dec 01, 2007
    same problem - immediately overflows after base fills. Brand new unit.
  • Anonymous Dec 03, 2007
    Same problem here. Will return back to Costco. Looked good too bad it does not work.
  • Anonymous Dec 09, 2007
    Yup, same leaking base. It's going back to Costco tomorrow.
  • seamacs Dec 12, 2007
    Same problem although I bought one at Costco and liked it so much I got a second for another part of my house and the second one did the same fill and leak thing .
    I took it back to Costco today. I can say that from my experience that they work half the time.
  • Anonymous Jan 25, 2008
    same thing here too . . . . the problem is that the tank was not sealed so the pressure was not maintained and the water leaked out. we found a hole underneath the handle (you have to take the handle off) from where the water tank was cast on the machine. if any air gets in it will leak water everywhere, hence the tight seal on the lid on the bottom. i took it back to costco and they send them back to bionaire.
  • cerrito Nov 25, 2008
    We had it working, then went to refill at one point and water started to pour out the base. Can't seem to understand why because it has been working fine since purchase, and we haven't done anything to the unit.
I just bought the same one had had the same problem, what a waste of time!
Posted on Feb 22, 2008
Same problem — junk.  Will return it to Sears (Costco was out).
Posted on Feb 05, 2008
Bionaire instructions
how do you take the top off of the bionaire bcm630
Jan 02, 2014 | Humidifiers
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
How can i change the filter in my bionaire model bcm 7207
on that model that you have you need to turn the unit off , take the water tank off, then the base where the fan is should come off. under the main base the filter will be under that. all you do is take the old filter off and put the new filter on. if you have any other questions please let us know.
Feb 26, 2010 | Bionaire BCM7207-U Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
Mar 20, 2009 | Bionaire Humidifier BCM657U Humidifier
Bionaire BCM 6000 tower leaking issue
Thank you for the follow up but there was a price at the end for my question so I decided to find out myself. I bought this product which is not the greatest and if on top of that I have to pay for a little information that's a bit far !
Regards,
Michel
Feb 02, 2009 | Bionaire BCM6010RCU 3.5 Gallon Tower...
BIONAIRE BCM630 TOWER HUMIDIFIER stopped working
If you would like to buy a new tower without a tank, I will be happy to sell mine.
Aug 24, 2008 | Bionaire BCM6010 Humidifier
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Bionaire BCM630
Remove the water tank from the main unit. Now look down into the unit where the water tank sits. There is a small knob that you need to turn counter clockwise and the lower part of the unit incl the filter will slide out.
Sep 23, 2007 | Bionaire BCM6010 Humidifier
Hunidifier doesn't add enough moisture to air
here is the link to the manual for the w7 - they suggest a replacement wick filter would solve the problem due to bacteria or mineral build up - i would expect this to solve your problem as the only way these wicks can not soak up the water to the top is if they are clogged or the tank is empty. try the cleaning routine on page 9 first - might be enough but the wicks probably will need replacing soon anyway. http://www.bionaire.com/manuals/W7_English.pdf Hope this helps :)
Mar 08, 2007 | Bionaire W7 Humidifier
Bionaire BCM6010 Humidifier Logo
726 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
