SOURCE: Gestetner DSM645SP Error Code SC 322
After research it seems this problem is not easily fixed.
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
SOURCE: my gestetner copier dsm 616 use to show sc 322
That code refers to a Laser problem.
It could be toner dirty and only need to vacuum it. But you have to know how to get in the Laser unit.
If you do not have that knowledge i advise you to call your technical support.
