For better result download the pdf file
Peugeot 407 2004 2011 Diesel Repair Service Manual
SOURCE: 407
it is a warning of something fault in your car it is probably with electricity and you cannot know it you must go to a peugeot service center to fix it
SOURCE: peugeot 407 coupe 2.7 hdi p0069 fault code comes
o2 sensor needs to be replaced and computer reset by disconnecting battery negative cable for 1/2 hr then reconnecting. Good Luck!
SOURCE: My peugeot 407 hdi sw is saying depolution system
chek for a collapsed catalytic converter and/or a clogged exhaust system...if it only smokes when 1st started, it could need valve seals...chek for clogged charcoal canister too if equipped...
SOURCE: White smoke from my exhaust on my peugeot 407 hdi
Try to replace the dpi filter...then follow this method to "remove" the code after you replace the dpi filter:
try to reset the maintenance computer. To do that, remove the car key. Press continusly on the "check" botton on the dash board. Put the key in and switch to on, but don't start the car. Wait 10 seconds (on screen 10-9-7...-0). Nowthe maintenance computer go to 20,000 and erase all old warning report. If the engine light and the "depolution" warning keeps showing up after that, it means there are still fuel related problems. make sure you are using the right fuel and fuel filter!!!. Don't use cheap fuel/filter, like at supermarket store, etc..get them from real gas station/auto part store...
SOURCE: Peugeot 407 sw 2.0 hdi 2005 rear parking
please check with your manual and or contact your dealer
