Question about Acer Aspire 5100 Notebook
No keyboard touchpad or usb
I have an Acer aspire 5100 labtop and when I turn it on the keyboard, mouse and the USB frozn, dosen't work, but the screen process fine.
Have an Acer 5100 Aspire. Keyboard, touchpad both not working. If I hold down Alt+Tab+F10 while powering up the laptop will keep the computer from booting up, but nothing else. I have tried USB keyboard...
Do one thing performing the recovery option by ALT+F10 and restore your system to factory default
before that you take backup with the important data
Nov 16, 2010 | Acer Aspire 5100 Notebook
Acer Aspire 5100-3357 lost function of keyboard, touchpad and USB
hello, this has been one of the most reported problem with the 5100 model. i have 2 of them, and they have done the same thing! one i had 2 find and install a new mainboard-400 bucks! not very cost friendly. i did post a solution more than a year ago, but it is a work around that let me use the acer with the dead keyboard,touchpad,usb- you must buy a pcmcia usb card, it goes in the slot on the left side of the acer 5100. then a usb mouse and keyboard will work. (you can get this cardbus adapter cheap, as 400 bucks is 2 much. these pcmcia cardbus card come with 2 or 4 ports. this will let you use the pc, it has been a great solution for me and a lot of others, been in use over a year like this. acer is no help, unless you wish 2 spend a large amount of $. the one with the new board lasted about 8 months before the usb port stopped working for the second time, i then got a second cardbus usb card and have usb again. sorry for your problem.. good luck! do as i say and the acer will work again.( a problem model) just search for pcmcia usb cardbus you will find many 2 choose from- i picked the ones with the NEC chipset, as these are reliable! be well!
Sep 21, 2009 | Acer Aspire 5100-3357 Notebook
Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Jul 21, 2009 | Acer Aspire 5100 Notebook
After force shutdown keyboard, mouse USB touchpad are not working
inside xp you can go to the hardware section and uninstall the usb drivers. when you reboot the drivers refresh for the usb and you can continue as usual.
Mar 11, 2009 | Acer Aspire 5100 Notebook
My acer aspire 5100 as put me into trouble
i had the same problem. apart from keyboard and mousepad, all usb weren't working at all... except the pcmcia slot. so i bought a pcmcia usb card and plugged in the usb mouse and keyboard in those slots. it works! at least on my aspire 5100
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
KEYS AND MOUSE
Check to make sure your touch pad is not turned off. Regarding the keyboard you need to check to see if you have set the laptop to work off an external keyboard. Check the function keys at the top of the keyboard they are used to turn on and off the keyboard and mouse functions
Sep 07, 2008 | Acer Aspire 5100 Notebook
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Acer aspire 5100 model bl51
dear friend,
this is your system board fault
this is due to southbridge (ich4) or ATI (ixp460) dry sold damage.
you should change this ic to fix this.
go to the best repairing center near you.
Apr 09, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard,sound,touchpad all not working keyboard, touchpad and all usb ports stopped working
kINDLY CONNECT A USB KEYBOARD AND/OR MOUSE TO TROUBLESHOOT THE NOTE BOOK IF USB KEYBOARD/ MOUSE (EXTERNAL NORMAL USB DESKTOP KEYBOARD MOUSE). THEN WE WILL BE ABLE TO TROUBLE SHOOT
Feb 29, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
