Question about Sears 61301 Gas Kitchen Range
I can't get my burners hot enough, can't hardly boil water.
    Scholar:
  • 86 Answers
Need more informations about your problem, is it a new installation , or is it suddenly happens one day, then we can goes from there. God Bless.
Posted on Jul 25, 2009
How long do I boil hot dog weiners
All hot dogs are already cooked and can be eaten cold so therefore the cooking time can be from minimum of 5 minutes after water comes to a simmer , If you are working a business and have the dirty water dogs sitting in Hot water you can literally have them in the water all day but remember the longer that they sit in the hot water the grayer looking they become so keep in mind that if you are selling them at a stand you want to keep rotating them from the hotter water to the to the cooler water but if you sell enough or if your just cooking a few for yourself or company a 7 or 8 minute boil will be sufficient ! Hope this helps sincerely glenn
Feb 18, 2015 | Dogs
Why do burners not get hot? After rehooking to electrical power, due to a remodel, the burners don't seem to heat up as hot as they used to. Cant boil water on any of the 4 burners.
Could be not enough voltage on your 220.lines ( one wire lose or a bad breaker. or the wires are hooked up wrung causing it to try to operate on 110 instead of 220
Aug 17, 2014 | Kenmore Electric Smooth Top Stove
Boiler starts banging and jumping after 20 seconds of burner igniting and then hot water comes from the pop-off valve, what is the problem?
water flow not enough water boiling inside check manual bypass spring could be bad if ok if plumbing bypass only open half way
Feb 13, 2014 | Raypak Pool & Spa
My ge range takes forever to preheat, and all 4 burners don't get hot enough to boil water.
Its not getting enough power could be a short before the control panel...check it again.
Jan 31, 2013 | Refrigerators
Both 6" plates on samet hob not getting hot enough. Replaced both plates changed, but still have same problem, not getting hot enough. What can problem be? Plates are getting hot but not hot enough to boil...
-The burner itself has burn connector. Take it out and check. If it burn very bad then need to replace new burner. Or may be the connector itself.
Good luck
Mai
Jan 25, 2018 | Cooktops
I have a 3 burner that I got on ebay and it seems to want to get the water too hot. It gets hot enough that it sends steam from everywhere. I imagine that that is due to water boiling in the tank? I...
Hello, yes you are correct, it's due to the water boiling in the tank. take 2 screws out of the top panel, just under this panel you will find the thermostat (it's ajustable) turn the temp down on the thermostat, if this does not solve the problem your thermostat may be bad and you will have to replace it. You can purchase new parts from either bunn direct or from holiday house in california. if you have any additional questions please feel free to comment again. Good Luck! Mike
Oct 16, 2009 | Bunn VPR Coffee Maker
Bunn VPS 3
Are you leaving the machine plugged in all of the time? If not, you need to. The machine takes approximately 10 minutes to get to full temperature the first time then the water should stay hot from then on. Or it could be that you just need to turn up the thermostat. No, the water won't get hotter sitting on the burner and the coffee won't taste as good if the water you are brewing with isn't hot enough.
To get to the thermostat, unplug the machine and take the two screws on the top lid off. You should see a box that has a knob or a T sticking out of it. Turn it up a little bit, put the lid back on and let the heat up for a little while (10 - 15 minutes). Try brewing with just plain water. If it still isn't hot enough, repeat the steps above. Make sure you don't turn up the thermostat so much that the water boils.
Nov 06, 2008 | Bunn VPS Coffee Maker
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Wo'nt boil water
PS The four asterisks are supposed to read "k n o b". There is an apparemnt problem with the website's text checker program.
Mar 10, 2008 | Maytag MER5770 Electric Kitchen Range
Sears 61301 Gas Kitchen Range Logo
61 people viewed this question
Top Sears Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Sears Kitchen Range Expert? Answer questions, earn points and help others
