Question about Amana PTH123B25AJ Heat Pump Air Conditioner
My Amana PTAC vibrates and sounds like it has glass packs when the AC compressor is on, is it fixable?
SOURCE:
oscarn
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
SOURCE: I have a new Amana
when its quiet its the electic heat thats being used when its loud its the heating pump and the heating pump is what saves you energy and they can be a little loud when its on its normal. I work on these units at a hotel
Posted on Jan 11, 2011
  • 414 Answers
SOURCE: amana ptac ac turn on
If this unit has the old style control with the knob instead of the digital control panel
then I would suspect this first. This is the first component to fail on these units. I have
replaced two already and the kit has good instructions and all components.
Takes approximately an hour to do and mount the new sensors. (The transformer is
hidden beneath the sheetmetal just below the control board). You should be able to order this kit through any appliance parts store for around 175 dollars versus almost
800 dollars for a new PTAC. Hope this is helpful.
Posted on Jun 26, 2011
hellrayz
SOURCE: I HAVE A AMANA PTH153B50AE PTACT UNIT. ANOTHER
The RSK is VERY specific on programing
Read the manual failing that email me and explain how to do it.
VERY VERY easy
Posted on Aug 02, 2012
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
Do you have an amana ptac wiring diagrams?
Sounds like you need a new control board.
Sep 03, 2014 | Amana PTC124E50AXXX
I have an amana ptac model pth153B50AM it does not seem to cool much at all but I do hear the compressor come on.Before i cost myself a couple thousand dollars can anyone tell me is this fixable?
yes it is fixable does the blower run? I would pull it out take it outside and wash with hose the outside coil and inside coil make sure you clean the outside coil real good on both sides. this may solve your problem.
Jul 30, 2014 | Amana PTH153B50AM Air Conditioner
AMANA PTAC NOT COOLING
on most ptac they have electric heat so there is seperate controls for cooling it is possible a contactoer or compacitor
Mar 30, 2013 | Amana Heating & Cooling
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have an Amana PTAC that was just installed two weeks ago. I am starting hear a moderately loud warbling sound when it is in operation but not all the time. It's loud enough to wake me up in the next...
Is is the sound of water being thrown around? Some units actually sling the water from the drain pan back onto the coil. This improves efficiency. It's sort of a gurgling sound. Here's more helpful information is you need it:
<a href="http://www.ultimateptac.com/ptac-faqs/">PTAC FAQs</a>
Dec 19, 2010 | Heating & Cooling
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
297 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
