Question about SySTOR Systems (400S52) Burner
I am trying to replace my gas oven burner igniter
My burner igniter part is 5308009420 for a Kenmore Gas Range, model 790.7482190
Please leave us some more detail about the problem you're having installing the component.
Posted on Nov 19, 2007
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Oven will not light
If your husband is handy and it is Igniter.. this is a job he can do. remove the burner cover and them the burner baffle and unscrew the igniter cover and pull the igniter out remove the wire nuts and replace with igniter part number WB02X9154 let me know how it works out for you.
Nov 18, 2007 | GE JGRP17 Gas Single Oven
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a kenmore gas range the oven seems to light the oven burner ever 10 sec and wont stay on model # 362.75497000
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 26, 2011 | Kenmore 71052 Gas Kitchen Range
Gas oven on Kenmore range model 362-75191890 went off midway through roasting Thanksgiving turkey. There seems to be no gas getting to the oven burner, even though the range top burners fire up nicely.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Kenmore Kitchen Ranges
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Dec 06, 2007 | Kitchen Ranges
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Computers & Internet Logo
46 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
