Question about InFocus Office Equipment & Supplies
In-Focus LP-130 and it turns on but the lamp wont fire up, it sounds like the cooling fan goes on and then stops, its a brand new bulb also.. some one said its daughter board that controls the cooling lamp that is bad... any help would be appreciated
  • 3 Answers
If the bulb turns on for only for a few secs then goes back off, you need to reset the Bulb Hour Timer. http://www.infocus.com/Support/LampHours.aspx I just fixed my LP130 this way. I replaced the bulb once, but didnt reset the timer then.
Posted on Jan 28, 2010
  • 2,237 Answers
The ballast is bad. the fan turns on for the colorwheel, but when the lamp doesn't strike, the fan and colorwheel turn off until it tries again. unfortunately, there are no replacement parts for the lp130.
Posted on Nov 06, 2009
My projector worked fine for 2 years now it overheats it seems and shuts off i put a brand new lamp in it it still does it after 5 minutes or so
cooling fan , I wish they'd include a new fan as well with selling ya a new bulb , but last they don't , I find many times the cooling fan goes and that's what makes the bulb go (heat)
Feb 26, 2016 | Office Equipment & Supplies
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Hi There... I have problem with my Infocus LP 130 The power is still ON, fan at the back is still working caused I can feel the air flow, but no light coming out from the lens. Can you please advise, what...
theres another fan next to the engine. all fans must work for the lamp to light. the colorwheel must be turning freely for the lamp to light. you can also take the top cover off and then slide the lamp out and then back in while watching to see if the connection on the lamp is pushing the female part on the lamp housing back instead of going into it. if it is, hold the female part in place with a driver or something while pushing the lamp into it.
Jun 01, 2010 | InFocus LP 130 Multimedia Projector
New Bulb in my In-Focus Lp130 wont light
the connection that the lamp plugs into backs out of place preventing the connection from being made. you will have to remove the top. with thetop off, install the lamp and look to see if the lamp connection is going into the connector on the lamp housing. if not, you can get a flathead and push the connector into place on the lamp housing and hold it there while pushing the lamp into place. to keep this from happening again I always used to melt the connector to the lamp housing with a soldering iron.
May 26, 2010 | InFocus LP 130 Multimedia Projector
My sony wega's picture goes on and off, but doesn't power down. it's not as if the lamp stops, but only shows blackness.
It is the lamp cycling imagine its like a street lamp, it turns on gets to temp then powers down because of too much draw.
I suggest new bulb and take apart set to clean all cooling fans and take apart projector assembly as cooling fans in there become clogged with dust.
Apr 18, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
If the cooling fan on my Vizio RP56 stops working, will it cause my screen to go blank, seems like bulb will not work if cooling fan is broke.
The fans are all monitored by the Micro. When one goes down, especially the lamp fan, they will not fire. If the fan is bad, replace it. If it's not I would call a service company.
Nov 03, 2009 | V, Inc. VIZIO RP56 Rear Projection...
Turn on and red light comes on after two min. and it shuts off
on that model its possible for the lamp sockets from the ballast get pushed back inside the tv. Remove the bulb and verify that the sockets are firmly attached to the rear wall of the lamp compartment.
Jul 13, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
Infocous LP 530 Light comes on then stops
this could be one of three issues. the power supply. the firmware or the lamp. thebulbman.com
Feb 03, 2009 | InFocus LP 530 Multimedia Projector
Infocus 540 lamp didnt strike keep trying
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
1,121 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
