Question about Yamaha DVR-S150 DVD Player
Disc skipping and freezes for a second.
My cinemaStaion seems to freeze for a second over and over. Not just DVD's. Sometimes it is intermittant. No dust seen.
  • 236 Answers
Re: disc skipping and freezes for a second.
Your paser lense is already weak. has to be replaced. very costly, sometimes more practical to buy new unit. i have my old DVD-S700 two of them and both of them the same problem lense. not only is it expensive but veryhard to find.
Posted on Mar 31, 2008
I am French I can tell you that the repair of the lens is very costly. It is practically the price of nine. Guess ...
€ 250!. On the coup's my agitated. Decevant it from yamaha. Both buy another home cinema.
Posted on Mar 28, 2008
Je suis francais je peut vous dire que cette reparation de la lentille est très couteuse. c'est pratiquement le prix du neuf. devinez...
250€!!. sur le coup sa ma enerver. c'est decevant de la part de yamaha. Autant s'acheter un autre home cinema.
Posted on Mar 23, 2008
0 characters
3 Points
My lg dvd (dv 490) plays dvd then after about 30 minutes,starts to skip a couple seconds which gets worse gradually before its starts to freeze and auto-eject discs.i opened it and noticed the driving...
Sounds like sled motor [the motor that help to spin the disc inside] is faulty. This is purely a mechanical fault. Contact any service technician. The CD drive mechanism should be taken out from the device, for repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Nov 22, 2014 | DVD & Blu-Ray Players
Image/Sound Freeze-up
the problem is the laser, or lens of your dvd, try cleaning it using lens cleaner..
Jun 21, 2010 | Sharp DV-600U DVD Player
Rented videos are freezing temporarily during playback
If the rented DVD is too scratched it will cause the DVD player to pause while it tries and find the next available playable area on the disc. This may cause the player to skip to another part of the movie. Try wiping the disc with a damp cloth from the centre towards the outer rim and dry the same way. Fingerprints ect. also cause problems. If the scratches are circular the player will have a hard time trying to play the disc. If the scratches are straight and small it shouldn't cause too much problems.
Mar 17, 2009 | Sharp DV-SR45U DVD Recorder
DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Jan 21, 2009 | DVD & Blu-Ray Players
DVD player: all disks freeze or skip at same point.
with some models it's very sensitive to being level. try moving your dvd player to a common flat area. see if it's a little rocky or placing a single piece of paper under one of the corners...I had a dvd player that would freeze on every disc and since I moved it to the botton of the cable box it no longer locks up. Worth a try.
Jan 04, 2009 | Denon DVD-800 DVD Player
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
DVD Freezing / skipping
It almost has to be the discs. Try them in a friends unit.
I had a similar problem with DVD's I burned and had printed labels and put the label on the discs. It caused the disc to be out of balance. I peeled them all off (what a job) and the discs play fine now. I'm now a "magic marker" person... :)
Feb 09, 2008 | DVD & Blu-Ray Players
Picture stalls/freezes
Clean laser lens with canned air Then clean the rubber circular area off (part that disc fits onto) then try to see if it stops freezing &skipping.
Jan 11, 2008 | kawasaki PVS-10921 Portable DVD Player
damaged or dirty disc-clean or replace
Dec 27, 2007 | NexxTech DP3222 DVD Player
DVR 120 Disc/Screen freezes half way through
CD does not run
Clean lens and adjust the disk level
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
This fault would only occur on c.d play back. The sound would gradually start to distort, until all that could be heard was complete distortion. This fault was intermittent and would occur whenever it felt like
Believe it or not,this fault was cured by replacing the optical unit
Nov 24, 2007 | Samsung DVDR120 DVD Recorder
Yamaha DVR-S150 DVD Player Logo
131 people viewed this question
Top Yamaha DVD & Blu-Ray Players Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
