Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Removing the agitator
I have a Frigidaire Gallery stack washer/dryer that has something caught around bottom of agitator. How can I remove the agitator to fix it? .
  • 23 Answers
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Posted on Nov 04, 2008
I have a FEX831FS4 that will not agitate, however, it will drain and spin. Where should I start the diagnosis process?
Start right here:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FEX831CS0/1428/0152000/R0310016/00005?blt=06&prst=&shdMod=
This will give you a good idea of what you are looking at and where it is located as-well-as the expected costs of parts. Keep in mind though eBay is now a great place to get parts. Often for way cheaper than a parts outlet will charge.
It's kind of unusual for a machine to just lose agitation, unless it has a clutch or maybe agitating dogs; however, this unit has neither that i see and i must confess i've never worked on one. It's possible #2 on the transmission diagram is worn. Does the agitator spin? It may turn a little, but should not spin around like there is nothing holding it. If it does it is either the agitator or the part it connects to (# 2) or an associated part. Removing agitators can sometimes be a pain. Warming an agitator up with a hair dryer can make all the difference in the world when something seems stuck.
Good Luck.
Jan 07, 2013 | Frigidaire FEX831CS Top Load Stacked...
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
My Frigidaire front load stacked washer/dryer makes a horrible noise and won't spin. It works perfectly except for the spin cycle
you need to remove the agitator take the cap off and remove the bolt from inside the agitator and then remove it look at the metal trunion in the bottom of the tub and see if there is a broken bolt holding the trunion to the shaft.there is a chance the transmission need to be replace if there is no broken bolt
Nov 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Quentin
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
Towel caught under agitator
remove the top part of the agitator and inside youll see a nut that will have to be taken loose so tht you can get the agitator to raise up high enough to get the towel out
Feb 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Sheet caught under agitator
the agitator comes out..... by simply taking off the cup that holds fabric softner, just pull upward if needed wiggle and pull. under that you will see a raised plastic piece the raised plastic pc is pulled of by using a pliers pull upward under this you will find a bolt 1/2 or 9/16 socket remove bolt and pull out agitator same way by wiggling and pulling upward
Jan 08, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
663 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
