Question about Canon PIXMA iP1800 InkJet Photo Printer
Feeding at the right side, paper gets jamed and it wont feed
  • 21 Answers
Sorry for my stupid question, but doesn't your printer have a guide for lining up the Paper? If so and it is on the Right Side, I would imagine that you have worn the Rollers or possibly the Pickup out.
Keep in mind these items are consuable and are, designed to wear out, design is a bad term, but it's just like the brakes on your car....at come point you need new pads.
You can check the Pickup easy, the rubber should be above the plastic, if it is level with the plastic, time for a new one.
You can buy Printer Cleaner paper designed to pick up dirt, oil, etc from the rollers, and other parts the paper comes in contact with. After using this you should be able to print a few sheets, but it will quickly die again, but know you know you need a new roller set for your printer....plus its not a bad idea to have the print cleaning sheets around anyway...their pretty cheep.
Let me know how it goes.
Posted on Jul 25, 2009
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
My fax machine keeps jaming on the right side in the paper tray, what causese this
When it jams, does the paper get bent or crinkled? If so, there is probably something lodged in there causing the paper to stop. Could be a paperclip or staple, or maybe another piece of paper.
If there is nothing blocking the paper and it just stops feeding on one side, you may have a tension problem -- springs might be getting old and not pushing rollers together tight enough to feed the paper. If you can take the machine apart, try switching the springs around to see if that makes a difference.
May 26, 2010 | Brother IntelliFax-4100e Fax
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Getting paper feed jams
Hello sir; Try to press the "clearmode " key , on the right hand side top of the control panal.
Jan 31, 2010 | Gestetner DSm645 Digital Imaging System
Paper will not feed on right hand side. Goes in crooked
the wheel is worn down. cheaper to get a new printer. you amy also have a small peice of paper wtuck. turn the printer around and take off the cover plate. look for msall paper jamed ont hat right side under the wheel.
Dec 04, 2009 | Canon MP970 Photo All-In-One InkJet...
Lexmark Z715 printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.IF the problem continues then its the problem with rollers in the printer ,hardware problem ,
Good luck....
Aug 22, 2008 | Lexmark Z715 InkJet Printer
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
EPSON STYLUS PHOTO RX425, PAPER PROBLEM
disconnect the printer from the computer:
>manually feed paper using the paper feed button.
>observe, if the printer pulls only one side of the paper then it´s a hardware issue
Jan 01, 2008 | Office Equipment & Supplies
Paper Jamming
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Jun 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
112 people viewed this question
old marine
old marine
