Question about Lexmark Wheelwriter 3 Typewriter
How do I get the left margin to change? - Lexmark Wheelwriter 3 Typewriter
  • Lexmark Master
  • 3,594 Answers
Return to L. mar. press and release mar. rel. key, backspace to wanted location, press left mar. key. On a WW3 the machine will not remember the margins when turned off.
DickyO
Posted on Jul 17, 2009
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
Change left margin on IBM wheelwriter 2000
To change the left margin, hit the return button which will take you to the left margin. Hit the margin release lever (mar rel) and then the backspace button to go farther to the left and stop where you want the margin to be. Hit left margin and that is where it will then be set.
May 09, 2014 | Lexmark Wheelwriter 3 Typewriter
Left margin cuts off
Try changing the left margin size in the page setup. Decrease the left margin size.
You could also try printing in Landscape instead of Portrait just to see if it captures the left margin.
May 31, 2012 | Samsung CLX-3175FW Multifunction Laser...
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Mar 19, 2009 | Brother ML-500 Typewriter
How to reset margins on kx-r340 typewriter?
Hi;
To set or change the left margin space forward and press the left margin key. If you want to go in the other direction the press the margin release key once(do not hold it down) the use the backspace key to get to the point where you want to set the margin and press the left margin key.
The setting of the right margin works the same way.
Andrew
Mar 15, 2009 | Nakajima AE-740 Typewriter
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
Swintec 2000 Margin
You should reset the margins where you would like them. To do this, go the the file screen and press MARGIN. Press <--- to change the left margin, or ---> to change the right margin, or the up arrow to change the top margin, or the down arrow to change the bottom margin.
Do one at a time. When you choose one (i.e. <---), the message "LEFT MARGIN SETTING" appears on the screen and the cursor moves to the left margin column automatically. Move the cursor to the desired location by using the arrow keys. As you move the cursor, the corresponding margin mark moves along with it. The press "DO" to set the new margin.
Hope this helps.
Jay @ www.granadahillsbusinessmachines.com
Aug 26, 2008 | Swintec 7040 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
