Question about Video Game Consoles & Games
Driver Parallel Lines PS2 Problem
I bought Driver Parallel Lines on PS2. It loads up but when I get to the menu it says "Controller disconnected... etc" even though the controller is blatently connected and I proved this by inserting another game and watching it run perfectly. Any ideas?
  • 97 Answers
Hmm if u bought from walmart or a retail store just take it back and get another copy
Posted on Aug 02, 2009
My old ps2 controller is not working. i used a new controller but it still doesn't work. the new controller was tested on another unit and it works fine. so i guess its the console itself is the...
See if your ps2 controller hub or port is damaged. If any pin is twisted try to get it straight and if you can't fix it, take the console to a service center.
Oct 13, 2011 | Sony PlayStation 2 (PS2) Console
Need raid contoller drivers for Asus P4XP-X
http://majorgeeks.com/DriverMax_d5260.html Win7/Vista/XP . DriverMax is a new tool that allows you to download the latest driver updates for your computer. No more searching for rare drivers on discs or on the web or inserting one installation CD after the other. Just create a free account, log in, and start downloading the updates that you need.
You can also export all your current drivers (or just the ones that work ok) to a folder or a compressed file. After reinstalling Windows you will have everything in one place!
Most of the situations when Windows is running slower are caused by faulty driver installations. Windows stores all versions of older drivers just in case you want to go back; sometimes it messes up older versions with more recent ones. The Export Wizard will only export the drivers you select by copying the needed files to a folder or a compressed ZIP file.
After reinstalling Windows all drivers will be back in place in less than 5 minutes - sparing you of searching, inserting disc after disk and losing precious time. The Import Drivers wizard allows you to install all the drivers that you exported earlier. The entire operation might take up to 5-10 minutes.
Just one single computer restart will be required after all drivers are reinstalled!
DriverMax is able to display a complete report of all drivers (versions, release dates) installed on your system. This feature can also be very useful when you want to analyze the differences between the drivers installed on different machines. Hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/nvidia-raid-driver-zip/3000-18492_4-158932.html This package supports the following driver models: NVIDIA NForce(tm) ATA RAID Class Device
  • NVIDIA NForce(tm) ATA RAID Class Controller
  • NVIDIA nForce2 ATA Controller (v2.6)
  • NVIDIA nForce3 Parallel ATA Controller (v2.6)
  • NVIDIA nForce 3 Parallel-Serial ATA Bridged Controller (v2.6)
  • NVIDIA MCP2S Serial ATA Compatible Controller (v2.6)
  • NVIDIA MCP2S Parallel ATA Controller (v2.6)
  • NVIDIA nForce3 250 Parallel ATA Controller (v2.6)
  • NVIDIA nForce3 250 Serial ATA Controller (v2.6)
  • NVIDIA nForce 2 ATA Controller (v2.5)
  • NVIDIA nForce 3 Parallel ATA Controller (v2.5)
  • NVIDIA nForce 3 Parallel-Serial ATA Bridged Controller (v2.5)
  • NVIDIA MCP2S Serial ATA Compatible Controller (v2.5)
  • NVIDIA MCP2S Parallel ATA Controller (v2.5)
  • NVIDIA CK8S Parallel ATA Controller (v2.5)
  • NVIDIA CK8S Serial ATA Controller (v2.5)
Apr 11, 2011 | ASUS P4V8X-X Motherboard
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
I can't operate any games in 2 player mode
Many games require original PS2 dual-shock controller. Make sure that you have original controllers.
Jul 10, 2010 | Sony PlayStation 2 (PS2) Console
Need to selct english on the ps2 box itself,its in asain can u help
Remove any disk and close the disk tray. Turn off your system and let it sit for a few seconds before turning it back on. Select the "Language" option from the main menu to open the language menu.
Move the cursor up using the directional pad on your controller until you get to "Language Select." Push the X button repeatedly until it lists "ENGLISH." This changes the audio settings from English to Spanish.
Scroll down to the "Subtitles" option in the language menu and change this setting to Spanish as well. The subtitles will appear in ENGLISH at the bottom of the screen every time a character in the game speaks. If you wish, you can skip this step and rely only on the audio settings.
Press the Circle button on your controller to move back to the main menu, which will save the settings. Select the correct time and date setting for your time zone, if the system asks you to do so. Push the Circle button again to access the main menu.
Place a PS2 game into your console and let the game load. You should now have ENGLISH, settings on your PS2, including subtitles.
May 05, 2010 | Sony PlayStation 2 (PS2) Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Microcon wireless ps2 controller not working.
mad catz stuff is **** and most wireless controllers all brake
Apr 20, 2009 | Mad Catz Lynx Wireless Controller for...
Mad Catz Lynx Wireless Controller PS2 with blinking red light.
I have one of these and what i usually have to do is plug the little part in which plugs in to the ps2 then let that load for a few seconds then try turning on the controller.
Hope it helped =]
Dec 30, 2008 | Mad Catz Lynx Wireless Controller for...
Logitech nascar racing wheel ps2
Make sure the driver is correctly installed for the hardware. Also if for a game in the options menu should be something along the lines of controller or input, just change the input to the pedals
Nov 06, 2008 | Logitech NASCAR Racing (963339) Wheel And...
Lost my password for ps2
Put a DVD into the PS2 and let it try to load. When the screen says chenge to level four select yes. When the entry window pops up,press the select button on the controller. It should say reset password or something like that. Put in 7444. Then when you rename the password put in 0000. You will have to do it again 0000.
Once the movie starts, not the menu screen, but the movie actually playing, Press Select button again. The PS2 DVD menu should appear. Cursor over to the toolbox or Setup, and press X. Cursor over to the third icon, and press X. Arrow down to PArental and press X. Change the Parental lockout to OFF.
I am not completely sure about the procedure here but the numbers are correct.
Nov 11, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
168 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
