Question about Grilling
I am looking for a new valve or orifice for a 2002-2003 char-broil BBQ
  • 525 Answers
Below is the replacement parts website for your model grille.
http://www.charbroil.com/consumer/product_detail_e.aspx?ProductID=891
Posted on Jul 17, 2009
The middle burner puts out gas, but the two outside burners do not.
Not enough information. If we assume the other two control valves are turned on, are the orifices clogged, are the valves leaking, are there safety valves attached the the natural gas line to detect leaks?
look down inside the valve stem to see if there is a tiny screw. this is an adjustment for the valve to allow more or less gas flow. if the valve was damaged or tampered with this could generate better flow. if the appliance went a long time without being used the valves could be clogged. remove the orifices and blow out the orifice and the valve with the orifice removed.
Mar 09, 2014 | Char-Broil Commercial Stainless Steel...
Char Broil Gas BBQ Knobs just spin, no propane coming out.
Just a wild guess but I think on a Char Broil you have to push in the knob and turn it to the setting.
Feb 24, 2013 | Grilling
The side burner makes a clicking noise, but doesn't light. what could be causing this?
You may have a clogged orifice in the valve. You have to take the side burner apart to get to the valve orifice. Use a straightened paper clip to check for a blockage.
Aug 13, 2011 | Char-Broil Commercial Stainless Steel...
Cb-6000dlx-w char broil bbq. (4646166) I purchased this bbq around 8yrs ago and believe it or not I have just taken it out of the box! however there are no assembly instructions with it!!! I have tried...
Barry, short of contacting Char-broil Customer Support 1-866-239-6777, I doubt there is one available.I checked my list of over 100 Char-Broil models and it wasn't on it. In addition, you may need to replace the Hose/Regulator that came with that model, as it probably won't fit today's grill tanks. But, it's not a big deal. You can pick one up at any hardware store or home improvement center that sells grills and accessories. The run about $30.00.
Good luck in your search and thanks for choosing FixYa.
Jul 30, 2011 | Grilling
I am looking for 4 orifices size 115 for a char-broil bar-b-q. Can you provide them?
Hello, You will likely need to contact Char-Broil directly. Their website is: http://www.charbroil.com/
May 20, 2010 | Char-Broil Advantage 463453306
Have a 2 year old char broil bbq, have to start it with a match as auto doesn't work. started it and came back out after 5 mintutes and it was off. replace with new propane and wasn't getting any gas flow....
More than likely, the valve at the barbeque is clogged. Sometimes spiders will plug the valve since they are drawn to the smell of the propane. You can either clean the valve or replace it.
http://www.charbroil.com/consumer/ReplacementParts.aspx
Jul 28, 2009 | Char-Broil Grilling
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
Orifice
Visit:
http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1010&CategoryID=
They have replacement parts for this grill.
Aug 26, 2008 | Char-Broil Grilling
I dunno, I have not done the conversion for this particular barbecue, but the kit is listed in the parts list for that barbecue,
It would be appropriate at this time to print the conversion instruction manual and take it to a local 'guy' a gas fitter.
The instruction .pdf shows them converting 3, 5, 7 burner units with the same kit, and states
  • Insert orifice removal tool provided with kit onto firebox burner openings and unscrew orifices from valves.
    Save removed orifices for later if converting back to LP Tank Gas.
    The valves are designed to work with natural gas once orifices are removed.
    Do not replace any Orifices when using natural gas.
    NOTE: your gas conversion kit comes with replacement orifices for the Rotisserie Burner ONLY, do not use on Tube burner valves.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%204584609%20ng%20conversion%20kit.pdf
seems the same 2-burner kit is for all barbecues
I think the person on the phone messed up, but a gas-guy would know for sure
Jul 01, 2008 | Char-Broil Advantage 463453306
Grilling Logo
83 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
