Question about Garden
Toro 6.5 self propelled Mower - Self Propell won't engage
When I engage the Self-Propell, it rumbles and the wheels only move slightly then stop, I removed the wheel thinking maybe it stripped the inner gears on the wheel but they are not stripped, I made sure the cord was tight and when I pull it, it tightens the belt around the mower blad shaft, do you think it could be the actual gearbox? What other troubleshooting steps can I take?
  • billys_vshd Jul 17, 2009
    The lever works fine, when I pull it, the belt on the blade shaft tightens.
  • 202 Answers
See if the lever going to the gearbox is cracked or broken. there is a gear inside the box that has a pin going thru the shaft that may have broken but usually it is external. these mowers have a plastic lever to put the transmission lever in gear if the cable is overtightened they wont hold up.if it cracks it leaves practially no tension on the engagment system
Posted on Jul 17, 2009
  • dewey wyatt Jul 23, 2009
    you are looking on the wrong end of the cable. not the handle the lever on the transmission is the one i am talking aboutthe outer part of the cable goes thru it before going thru the deck.if the plastic levercracks you wont get the wheels to turn thru the transmission.
My self propell lawn mower stop propell
the cable needs tension to engage the belt tensioner
Sep 23, 2012 | Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Self propelled #860. self propell got slower and slower. now barely assists. can I adjust the belt. manuual says bring it in. too far. how do I tighten? thx, bruce
Your self propell is not adjustable. The belt runs over a spring tensioner,you either need a new belt or axle bushings. If you pull the top cover off, you can watch the belt when you engage it. With the engine off, can you move the front wheels up or down or forward or backward? If so the plastic bushings are worn out and this changes the geometry of the drive system, making the belt appear too long.
Hope this was helpfull, Matt
Dec 31, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Self Propell Does not work?
The first thing I would check is remove the drive wheels and check to see if they are stripped out. Replace if nec. Also check to see if any linkage is defective, missing or what ever. If it has a belt check it, replace if nec. Once you get the cover off try engaging the self propel and see if things are working like they should.
Good luck
Sep 03, 2009 | Garden
Front ppropelled mower
You dont adjust the belt,you adjust the cable that moves the pulley into the belt. There will be a small single bracket close to the engine side of the mower that holds the cable in place. Simply loosen bracket and move cable until pulley contacts belt enough to engage self propel.
Aug 08, 2009 | Toro Lawn Mower With Toro Power Tools
6.5 toro walk behind self propell b&s engine. self propel does not work
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
May 30, 2009 | Toro Garden
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
675 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
