It is really easy to check this. Go to an electronics store and buy a cheap multimeter. It will cost you about $10 to $15. Set the multimeter to the ohms range and put the leads from the multimeter across what you want to read the resistance of. Done. If you are getting a voltage drop and are trying to find what the problem is, this may not be of much help however, as a high resistance may only show up when current is being drawn, as then resistance increases when faults get hot.
SOURCE: I need a diagram showing how to wire up a starter on a G9a yamaha golf cart
Hi Richard this link below should help you out....CHEERS..
http://mikes-golf-carts.com/golf-cart-parts/yamaha-wiring-diagrams-in-pdf/
SOURCE: why doesn't my yamaha golf cart charge the battery?
that would be a problem with either the alternator, or voltage regulator. make sure alternator belt is not slipping, then check with voltage tester at the alternator for voltage. if that reads good, then replace regulator.
