Question about Sony Cyber-Shot DSC-T1 Digital Camera
Screen is flashing E:61:10 and subjects are blurry, will not operate - camera was in the sand
  • 300 Answers
Hi!
The focus is stuck. The lens have to be cleaned or replaced. Contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Posted on Jul 28, 2009
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Pictures are appear blurry when reviewing them. I focus the camera object appears clear after I snap the picture it becomes blurry as it is being save for review.
Question : Why are my pictures out of focus (blurry)? Answer : This problem can occur for one or more reasons. Here are some common causes and suggested solutions.
  • The lens is dirty. Use a soft brush to remove dust and dirt. Wipe the lens gently with a soft, lint-free cloth or an untreated lens-cleaning tissue. Do not use cleaning solution unless it is designed specifically for camera lenses.
  • The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera has a recommended distance for normal, telephoto (zoom), wide-angle, and close-up pictures.
  • The subject was not within the effective range of the flash. Each camera has an effective flash range.
  • The camera did not focus or expose the picture correctly. For the best possible pictures, press the shutter button halfway and hold. When the Ready light or framing marks turn green, press the shutter button completely down to take the picture.
  • The LCD screen Preview feature was not used to take a picture in Close-Up mode. Always use the Preview feature in Close-Up mode to confirm focus and to frame the subject properly. If the Preview feature is not used, the LCD will not display an accurate view of the subject.
  • The subject or camera moved. Hold the camera very steady when taking a picture, or place the camera on a flat, stable surface. You may want to consider using a tripod or monopod.
Dec 08, 2009 | Kodak EasyShare Z740 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon powershot s3 is digtal
This is a menu setting, in capture mode it is the slow synchro option I think. What it does is try to get the subject to have a lit background. Turn this off and you get a subject lit with flash and no background but no blurriness either.
Jul 11, 2008 | Canon PowerShot S3 IS Digital Camera
Blurry and out of focus
Hey ammarhazem,
What is most likely the cause of your blurry pictures is that the on camera flash is not powerful enough to provide light coverage to your subject and the movement of your subject is causing the blurry images. Another problem I see is that you are shooting in Program mode, because in program mode you should have no control over the aperture and if your subject is far away and you are using the on camera flash you would want as wide of an aperture as you can get. I would shoot in aperture priority where you can choose the aperture and the camera sets the shutter for you and I would also invest in a more powerful hotshoe mounted flash. In regards to your red eye problem it is probably due to the distance of your subject from the flash also. How red eye reduction works is the flash fires a # of times prior to the exposure to shrink the pupils so the flash doesn't reflect of the subjects retina which produces the red eye problem. A hotshoe mounted flash would also solve this problem because the angle of the flash would not be as parallel to the lens as the on camera flash would be. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus FE-130 will NOT focus
It sounds like the focus motor in the lens is jammed. This could be caused by a knock or possibly sand. You could try tapping the camera (not too hard...). This might free up the motor the only other solution is to take it to a shop.
Apr 14, 2007 | Olympus FE-130 Digital Camera
Blurry screen
If you got sand/water in unit, it may damaged the circuits. You may have it cleaned completely, which could cost as much as a new camera.
Sep 12, 2006 | Sony Handycam CCD-TRV68 Camcorder
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Blurry pictures
It is possible you were shooting in the Night Scene mode. In this mode the camera sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should select Auto or Program mode for low light situations where you are taking images within six feet of your subject and the flash is required for proper exposure.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
140 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
