Question about Compaq Presario 700 470024-192 Notebook
Hp nx7010 not starting
My computer starts up, as normally, the lights on the start-button and on the front turns on and even the fan. After a few seconds the fan shuts off but the lights are still on, even though the screen and/or the rest of the computer is unresponsive.
The lights are on until I press the power-button again.
Could it still be a motherboard issue or could it be something else?
/Caroline
    Problem Solver:
  • 8 Answers
Hi
it is mother board problem replace it it will help full to you.
by by.
Posted on Nov 19, 2007
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
My computer lately will only start 5 -7 mins after i pressed the start button. And the motherboard fan is not working too. i experienced the longest start up time is few hours). Extremely slow...
Dude you got ! could be a problem with all of the above..
Most likely power supply. These things are so cheaply made that they simply do not last. Also u mentioned about your mobd fan please check that it turns freely by hand this could cause the problem as well. However i still say power supply
Apr 07, 2011 | Computers & Internet
But my laptop even don't work in safe mode. Blue screen appears and computer restarts again . What to do??
Try running the last known good configuration.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Jan 06, 2011 | HP Compaq nx7010 Notebook
How does the fan work in the 7010, is it always on or when it needed to. my fan worked for 3 sec on power-on startup and will not work after until the next startup.
It is normal. If the temperature of the system exceeds the limit, then the cooling fan will start to work.Run a film or video file for atleast one hour and check whether the cooling fan work after the sustem heats up.
Apr 02, 2010 | HP Compaq nx7010 Notebook
HP nx7010 - Blank Screen - wont load.
This looks like it can't recognize the hard disk or it's empty - no OS. To check that it's not a hardware fault just boot from a Linux Live-CD like http://pclinuxos.com/
If the hard disk is there and with all the data apparently intact then most likely the MBR was corrupted, fix it.
Jan 13, 2010 | HP Compaq nx7010 Notebook
Where do I find the button to start the Wi-fi ?
As far as I know - the wireless button is on the left of the power button (the middle one)
If I remember corectly, the button should have three "modes" tap once - bluetooth, tap twice - wifi, tap three times - both.
But that could be just my memory acting up and there could be only one mode (on/off) in which case - check if the wireless is enabled in the system settings and/or BIOS.
Nov 09, 2009 | HP Compaq nx7010 Notebook
Laptop HP COMPAQ NX7010. Dead, with lights on..
Sometimes removing the cmos battery for 5 minutes isnt enough, with all the parts assembled in the original configuration, remove the running battery, the cmos battery and any external power supply. Let it sit for about a day. Let my know if the problem is unresolved after that.
Notebook appears to start booting for about 3 seconds
See if you can get into safe mode by pressing F8 once you turn the laptop on. It will take you to a boot menu if it works properly, choose safe mode.
If you can get into safe mode then choose system restore and choose the last date the laptop was working properly. The let it restore your computer back to that date, it will need to reboot and it will go back into windows normally as long as restore went thru.
If you can't get into safe mode then you'll need to wipe out your drive and restore your computer back to factory defaults.
If you can't do that then you might have a bad hard drive and that would need to be replaced.
Aug 28, 2009 | HP Compaq Business nx7010 Notebook
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
Compaq Presario 700 470024-192 Notebook Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
