Question about Dremel Variable - Speed Multipro Rotary Tool 395
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
  • David Cole
    David Cole Jan 05, 2018
    hold the bit with pliers, let dremel hang then tap up on the pliers with hammer...that removes the bit and then you can turn the chuck.
    President:
  • 704 Answers
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Posted on Jul 24, 2009
Same thing happened to me... the collet rusted to the tool, and the collar froze as well. I used penetrating oil to loosen the collar, but ultimately, I had to disassemble the tool and use vice grips and pliers to remove the collar. Once off, I put a drill in the collet to fill the void and gripped it to twist and remove. Naturally, all four leaves of the collet broke off, leaving the remainder of the collet in the tool. After trying to thread the remains with a tap, I gave up and used a couple of drill bits to hog out the collet stub.
I don't know just how screwed up the tool balance will be having scored the collet sleeve, but I'll find out tomorrow... after I buy a new collet.
IMPORTANT TIP: Remove the collar and collet when storing the tool... This was a PITA.
Posted on Aug 30, 2009
  • 6 Answers
Remove the plastic nut covering the shaft. File two flats on the shaft on the raised flange just out from the bearing. Now you can use a spanner to hold the shaft while unlocking the nut anytime you have a lockup.
Posted on Apr 22, 2010
I have dremel 4200 ezchange bit broke inside collet how do i take collet out
remove the collet nut
use pliers or the like and pull the collet from the shaft jaws
remove the broken bit
put the collet back in the jaws and refit the nut
Oct 22, 2016 | Dremel Tools & Hardware - Others
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
May 12, 2011 | Craftsman 2.0 amp Rotary Tool Kit
How to use the collet wrench
There should be a spindle lock near the collet end of the tool. Engage it and then put the wrench on the collet nut and loosen the nut. If the bit is stuck just tap the end of it slightly to loosen it and it should come out. Reverse this process to install a new bit...hope this helps you...Jeepfxr
Oct 18, 2009 | Craftsman Tools & Hardware - Others
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
I have a Dremel 300, i think, lol.. standard Dremel... To losten the collet nut, you have to press down a button that locks the spindle so you can loosen it.. the spring and *** have stipped and it won't...
call dremel and ask for the part need you model number so have it ready Dremel Service Center Dremel Authorized Service 4915 21st Street 4631 E. Sunny Dunes Road Racine, WI 53406 Palm Springs, CA 92264 Phone: 1-800-437-3635 Phone: 1-800-275-2052 1-262-554-1390 1-760-327-3003
Jul 07, 2009 | Tools & Hardware - Others
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
My collet nut is stuck and I cannot remove it. Is there a trick to removing a stuck collet nut?
remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
Jun 27, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Nov 13, 2008 | Dremel 300-N/55 300 Series Tool Kit
Trouble Changing Attachment
Looking down on the collet end of the dremel, push red button and take pliers and turn locking nut in a counter-clockwise direction.
Oct 03, 2008 | Dremel Mini - Mite Cordless Rotary Tool
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
10,053 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
