Question about Frigidaire Dishwashers
BROKEN LATCH MODEL GLDB958JB
BROKEN LATCH ON FRIGIDARE DISHWASHER
MODEL GLDB958JB. CAN'T LOCK DOOR TO RUN DISHWASHER.
PART NO LONGER MADE. WILL SEEK ALTERNATIVES.
Posted on Jul 18, 2009
I cant get my dishwasher to start
Defective Door Switch?The next thing that could be causing your dishwasher to not start could be the door switch. This door switch is also sometimes called a door lock or door interlock switch. This switch is a safety feature and makes it so the dishwasher will not run if the door is open. If your dishwasher won't start, then it is possible this switch is bad. This switch is located inside the door panel. To determine if the door switch is bad, remove the control panel, locate the door switch, and test it for continuity.
Blown Thermal Fuse?Another part in your dishwasher that could be causing it to not start could be the thermal fuse. This fuse is designed to blow if the dishwasher overheats. If this fuse blows, it will need to be removed and replaced to make your dishwasher work. Most dishwashers have the thermal fuse located in the control panel area. To determine if the thermal fuse is bad, remove the control panel, locate the fuse, and test it for continuity.
Broken Door Latch?The part that holds your dishwasher door shut is called a door latch. 99% of the time this latch is made from plastic. If this latch becomes broken or cracked, it will prevent your door from closing properly. To determine if your door latch is bad, inspect your dishwasher door and be sure the latch is not broken.
Defective Main Control Board?The control board in your dishwasher supplies power to all components. If your dishwasher won't start, this could mean that the board is bad. If you have tested and confirmed working all the other steps above, then the control board in your dishwasher is most likely bad and replacing it would be a smart option at this point.
Jan 15, 2017 | The Video Game Consoles & Games
Hotpoint dishwasher won't latch
You may find the spring on the door lock assembly has broken and the latch has rolled over to the locked position you can check this by setting a program and if the pimp runs with the foot open the lock has failed
Jan 23, 2014 | Hotpoint 24 in. FDW60 Free-standing...
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Child lock on. How do you get it off?
I went out on a service call for this dishwasher yesterday. The complaint was that the door latch was broken and the child lock light was lit. I temporarily rigged the latch to work until the replacement part came in but that left me with the problem of the child lock still engaged. The mini-manual for this dishwasher is located behind the kick plate. The mini-manual revealed that the child lock (called a control lock in the manual) can be disengaged by pressing and holding the air dry button for four seconds. So now the customer can run the dishwasher with the rigged door latch until I can properly repair it later this week.
Hope this works
Jan 30, 2012 | KitchenAid 24 in. KUDU02FR Built-in...
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Latch on door dosn't lock when door closed
there is a ajustment or the latch is broken
Feb 10, 2010 | Maytag Dishwashers
Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Feb 15, 2009 | KitchenAid KUDR25 Dishwasher
Dishwashers Logo
69 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
