Question about Apple Audio Players & Recorders
My 4G ipod doesn't want to turn on at all!!! help I tried charging it on a wall charger and car charger but nothing helps. I first had it connected to the computer so I could add more music to it when all of the sudden it went ''blup'' and turned off
  • 11 Answers
Try holding the power button and the home button together for like 10 seconds
Posted on Sep 24, 2009
  • 126 Answers
Relax....
1. Make sure the Hold switch isn’t set to HOLD. 2. The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Then try turning it on.
If the above doesnt work then do the following.
1 Toggle the Hold switch on and off (slide it to HOLD and then back again). 2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
Posted on Jul 17, 2009
I've borrowed a friend's Garmin for a trip and when I use the car charger, it doesn't display anything. Once I disconnect, it becomes visible again. I'm going on a long trip and worry. ...
Assuming there is power at the cigarette lighter jack - turn the Nuvi off - then connect the charger. It should display charging battery or charging complete.
If nothing - does it charge with the wall charger? If so check the fuse in the car charger - it's usually in the tip of the charger which can be turned to get the fuse out.
Jul 05, 2011 | Garmin Nuvi 660 GPS Receiver
My ipod doesn't turn on it's blank
Step 1: Try charging your iPod with your wall charger, after about 5 - 10 minutes it should come on. (You might have forgotten to charge it)
Step 2: If that doesnt work, try step 1, but this time instead of charging your iPod with a wall charger, connect it to your computer. (Your wall charger may have malfunctioned)
If it still doesnt work, its highly possible that your iPod's battery might have died. If you bought it within one year, you can go to the Apple Store and get a free replacement on the spot (part of the warranty). If not, try to have them repair it for a fee OR give them your old iPod, and buy a new one for 10% off
Feb 03, 2011 | Apple iPod touch
Ipod wnt charge
Is the iPod's battery so low that it can't communicate with the computer? And what do you want to charge the iPod with? A wall-socket or with the USB If you have access to a wall charger, try to use that one. You could also ask a friend with an iPod if you can charge it in their charger. I had once that my batteries were so low it showed the "Connect to Power" screen and shut off due to inactivity, also if I tried to charge it in a dock. I tried to use another dock linked to an amplifier and it turned on immediately. Furthermore, what generation iPod are you using?
May 24, 2010 | Apple iPod nano
NS-DCC5HB09 High Definition Flash Media Camcorder: mine wont turn on and i dont have a charger!!! Hel...
You should be able to recharge this unit by connecting to your PC and charging through your USB connection.
If your battery is faulty or unable to recharge, here's a replacement battery that's available:
http://bestbuy.partsearch.com/GetModel.aspx?MfgName=Best+Buy+Company+Incorporated&BrandName=Insignia&ModelNumber=NSDCC5HB09&Page=1&SortBy=brandname&SortDirection=asc
Just about any AC to USB charger will work to recharge this unit, so if you have an iPod with the iPod wall charger, use the correct USB cable with the wall charger and you will be able to recharge the battery in the camcorder.
Hope this helps!
May 11, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Ipod doesnt work
I think I know just the problem. The connection cord that came with the wall outlet charger can only be used for charging. You have to have the original apple cord in order for the computer to recognize it.
I had the same problem.
Sep 20, 2009 | Apple iPod touch
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Apple ipod not getting charged
What type of IPod is this? Also what type of charger are you using? If the ipod does not have a charge at all you will need to plug it into a wall charger for it to get a "Base charge" (this usually takes 5-10 minutes) as if the ipod is totally dead then there is not enough of a charge for the ipod to let your computer know it is there to start being charged. After it has the base charge you can use the usb connection to finish the charge or leave it plugged into the wall charger to finish getting the charge.
May 08, 2008 | Apple iPod MA446LL/A MP3 Player
The new Battery does not hold charge.
if you charge it directly from the wall you may have a peak or an excesive charge due to a cheap charger or a defective one that may cause a short to a diode or resistor inside your ipod taking all the charge from the battery, Apple may charge you more than a new one is worth. But if you want to use it only for the car or the office you can keep it connected or into one of those nice sound sistems for Ipod is good, at least you wont have to throw it on the garbage. Next time try to use a sourge protector for all your electonics their inexpensive and they can save you a lot of money.
Aug 29, 2007 | Apple iPod MP3 Player
618 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
