Question about Kenmore Washing Machines
I have a sears 41799570110 stackable washer/dryer. dryer works fine but water won't drain out of tub
    Genius:
  • 1,122 Answers
Bad lid switch or clogged water pump-mike
Posted on Jul 17, 2009
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer and Dryer
there will always be water inside he machine(between the tubs, and in the hoses, but no so much to add that much weight so you cant move it, i would look to see of perhaps a levevling leg has hit the floor not allowing you to slide easily.
Dec 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Water will not drain on the spin cycle
sump'n peer's ta be stuck all down up n thar."--- thers an answer id go with..
backing to the rug ir perhaps the tassle ends have problaby clooged the pump assy preventing water from draining, i couldn't look up schematic firyou , themodel number was not found at sears website, but yea, defff sounds like there "sump'n peer's ta be stuck all down" the pump will hav a ghose leading to it, yuou should be able to flsh out the debris cant see needing to replace the pump
Apr 02, 2008 | Kenmore 98702 Stacked Washer/Dryer
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
85 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
