Question about Kenmore Dishwashers
Kenmore dishwasher -- makes loud almost grinding noise in wash
It makes loud almost grinding noise in the wash cycyle. I read the other posts for similar noises for other models, and was looking at my dishwasher to see about the tie wrap idea. The questions I was having was if it would work for a Kenmore and not just GE models? The other question is tying the tube to the basket does that mean you can't move the upper basket, or am I thinking of tying it to a different part?
4 Suggested Answers
  • 5911 Answers
SOURCE: noisy motor
It could very well be the wash pump motor starting to fail. It could also be something as simple as food and debris clogging the intake to the pump. The main wash pump is used to circulate water during the wash cycle. If the intake to this pump is clogged with debris, it can exhibit louder than usual noise during operation and lower water pressure. This particular model also has a chopper assembly just prior to the pump intake. This chopper can dice up some food particles, but cannot process things like popcorn kernels, tough pieces of meat, celery, etc. Basically, anything hard, fibrous, or tough. If you go to, theres an illustration of the pump assembly under the "Pump and Motor Parts" heading. The chopper is item(s) number 6 & 8. If anything gets caught in the chopper it will not provide enough water flow for the main wash pump. Double check the pump sump reservoir and make sure it is all clean. If it still exhibits the same symptoms, the motor may be damaged. I hope this helps you. Let me know if you need further assistance.
Posted on Jun 15, 2008
  • 1075 Answers
SOURCE: looking for a support part for the upper sprayer in Haier ESD210
easy to buy in any supply shop.adrian,,,,,
Posted on Jul 14, 2010
  • 552 Answers
SOURCE: Have GE GSD1150T64 dishwasher, 10 years old,
Take the lower kick plate off four 1/4 screws. The noise is coming from the motor itself. This is a very common issue on these units. The motor is held into the bottom with two 5/16 hose clamps.
Once the clamps are off the motor will fall down and slide forward. Simply slide the new motor into position and push up lock the two clamps and your done. The two wire connection on the front of the motor would also need to be removed and hooked back up.
Good luck with your repair friend
Posted on May 19, 2011
Hi, I have a Kenmore quietquard dishwasher model number 587.14012406a and it's making a loud noise throughout the wash it then stops and then restarts which is a vibrating noise and is extremely loud!
suggestion, i suspect you have got something in the wash pump or the pump impeller is breaking up this can cause a vibrating noise or it could be the rince pump.
Nov 20, 2016 | Kenmore Dishwashers
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
Won't spin and loud noise
Kenmore washers could hold a few problems. First, without a model number you don't know who makes it. See, Kenmore does not make washers, they have someone else make them such as Whirlpool or Frigidaire. More that likely you have a Whirlpool (which is a good thing). What you are probably hearing is the coupler of the machine broken. A coupler is what replaced a belt in the newer machines. This piece is installed in between the motor and transmission. If it breaks it makes a loud rattle/grind sound. It is possible that the transmission is also the culprit. However, this noise is entirely different. A bad transmission generally makes a loud screech noise. If this does not help, please post a model number of the washer and I will gladly further assist you :)
May 28, 2010 | Kenmore Washing Machines
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Loud noise
Very loud squeaking sound, at the start of each cycle.
Jan 09, 2008 | Kenmore 16639 Built-in Dishwasher
Dishwashers Logo
384 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
