Question about Samsung CLP-500 Laser Printer
Xerox phaser 6100 low fuser temperature - Samsung CLP-500 Laser Printer
  • 23 Answers
The only thing I know to do is to replace the fuser. When you buy a new fuser the installation instructions should come with it.
Posted on Jul 24, 2009
Xerox Phaser 4500 printer has a U4 fuser code.
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
  • Warm-up failure - Fuser warm-up not complete within 110 seconds after
  • starting.
  • Cool-down error - Cool-down process not complete within 200 seconds.
  • Low trouble temperature - The fuser temperature drops to the low trouble
  • temperature (approximately current control temperature, minus
  • approximately 25°C).
  • High trouble temperature - The fuser temperature rises to the high trouble
  • temperature (approximately current control temperature, plus
  • approximately 35°C).
  • STS circuit open
  • STS failure - The heat rod remains on for at least 10 seconds after warm-
  • up has completed
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
May 03, 2011 | Office Equipment & Supplies
XEROX Phaser 6100 service manual
We have the Phaser 6100 Service manual available at:
http://www.ccl-la.com/catalog/
Jul 20, 2010 | Xerox Office Equipment & Supplies
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Engine fuser low heat error on my xerox phaser 3500
You will need to replace the fuser.
You may want to look and see if you just have a piece of paper wrapped around the roll, but most likely the heating element has gone bad or one of the thermistors have failed.
Call 1-800-835-6100 and tell them the model number, and if it is a 120 volt or 220 volt fuser.
Feb 10, 2010 | Xerox Phaser 3500/DN Laser Printer
PRINTER XEROX 3100MFPX FUSUR TEMP PROBLEM
Most likely you have had a fuser failure. It could possibly be the fuser and power supply board.
If the fuser rolls melted together, I would replace both, if you can remove the fuser and are able to rotate the gear, then just the fuser needs replaced.
Call 1-800-835-6100. They can take care of what you need.
Jan 05, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Fuser Error. Low Temperature
there is a small thermometer that contacts/sits very close to the metal heat roller on your fuser, chances are when removing the jam its been bent away from the roller, have a look and try and see if you can see it, not knowing this exact printer im not sure the exact position but it is usually in the middle of the roller coming from the top of the fuser housing, another thing to check is if your fuser is actually warming up atall, if you cant feel any heat then the fuser lamp that heats it up has gone bad
Nov 14, 2009 | Xerox Phaser 6100/BD Laser Printer
Phaser 6120 fuser roller problem
try calling 1-800-835-6100 . Follow the prompts to order parts
Feb 04, 2008 | Xerox Phaser 6120N Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Samsung CLP-500 Laser Printer Logo
247 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
