Iomega s/n j3dj13005l portable drive won't open
SOURCE: IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
SOURCE: My Iomega Portable Hard Drive will not boot up
Hi Jim,
This may be a boot order issue. Can you boot the drive when it is unplugged?
Then, if you can, does it work if you plug it in after windows is up and running?
If the answer to both is yes, then you need to enter your BIOS/Setup as the computer first starts, with the Iomega drive plugged in and select your hard drive as the first boot device.
If you can provide us with more detail, we can give you the specific steps. Either way, comment back and either tell us it work or tells us more about your computer... Make & Model, and we'll do our best to walk you through it.
Chris
SOURCE: computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
SOURCE: Is it possible to open my Iomega Prestige 1 TB USB
Yes it is possible but the Iomegas are difficult to open and you often snap the plastic retainers in the process. Given you can buy a !TB comlete for only about $20 more than buying the raw drive I suspect you would be better advised to simply replace the unit all together,
Chris
SOURCE: solution CD for Iomega Network Hard drive 250Gb
You get the drivers at Iomega.com and look under support to get your drivers.
REMEMBER you need to install those drivers to ONE pc and then have all your computers networked to it thru your network neighborhood. Any other questions, please write back to me, ok?
