Question about Electrolux Kitchen Ranges
Frigidaire model ples389ecb with code f30. Replaced temp sensor, did not repair problem. What next?
3 Suggested Answers
  • 119 Answers
SOURCE: Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Posted on Jan 14, 2010
SOURCE: F30 fault code on model
F30 code fault means the temperature probe has an open circuit. It could be the probe or control board but probably not. There is two thermal overload switches in this circuit which may be tripped. One is located in back of range and the other is located in the front near right burner knob. Find these two switches and mash red button on them to see if it clicks and resets. Dana
Posted on Aug 01, 2008
I HAVE A F30 ERR DISPLAY ON BOARD AND THE DOOR IS LOCKED. HOW DO I RESET AND GET DOOR OPEN?
Hello Friend, this is Z. I am happy to assist you!
If you are getting an error code F30 on your Frigidaire range, it usually indicates an issue with a faulty sensor probe or a wiring harness between the sensor probe and EOC (Electronic Oven Control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC of your range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 05, 2014 | Frigidaire Ovens
My frigidaire does not heat consistently. F10 fault goes off if it's on for a couple of hours or if we broil. F10 also goes off after cleaning during cool down. F30 goes off after oven is turned off. ...
Good Morning Irene, thank you for allowing me to assist you!
The F10 and F30 error codes are in regards to an open or failed oven sensor. If the sensor and EOC has been replaced, more than likely a professional would need to inspect the wiring harness between the EOC and sensor.
Best regards!
Oct 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire electric range model FFES3025LSa
I have had the same problem. A repairmant has been out twice. I had an F30 code aalso which I believe is a temp sensor. However he replaced that and had to replace the control assembly to repair it. I have had it go out twice while under warranty and it just went out again. If you have a buzzing I would replace the control assembly.
Dec 01, 2011 | Frigidaire 30" Self-Cleaning Slide-In...
My oven gives an error code of F30 and the door lock flashes?
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Nov 16, 2010 | Frigidaire FEB30S5D Electric Single Oven
I have a professional series frigidaire stove and it keeps showing an error code of F30. What does this mean?
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jan 16, 2010 | Kitchen Ranges
Dec 26, 2009 | Frigidaire PLEF398AC Electric Kitchen...
F30 fault code on model ples389ecb
Jul 30, 2008 | Frigidaire Kitchen Ranges
Frigidaire Electric Range error code
Hi jacksmdmat,
Jul 16, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire stove door looked
temp was too high or the sensor smoked. this happens, self clean wreaks havoc with the electronics on this stuff. need your model to tell you what the error code means
May 10, 2008 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
300 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
