Question about RCA P46812BL 46" Rear Projection Television
Sounds like the problem my fisher 40" was having.
start by giving all of the circuit boards a very thorough cleaning, you can pick up crc qd electronic cleaner at autozone and other local stores. just make sure whatever you use is plastic safe, and you can use a soft bristle toothbrush to clean out any persistent crud. after everything is thoroughly clean and dry, test it.
if it doesn't work pick up a can of freeze spray from a local supplier, let the tv warm up, then use the spray to cool the components on the convergence board. see if the problem disappears. if this doesn't help, do the same to the power board.
if this does work, identify the component that is overheating and replace it.
if it doesn't work, check for dry solder joints (tedious process but worth it). this was the issue on my tv, am in the process of fixing it right now.
if you are still having the issue at this point, do a visual inspection for any capacitors that look like they have leaked or are discolored, test and replace any that are bad. do the same for other components.
this problem is more often than not caused by the convergence board or the power board, unfortunately for me and you both, i haven't been able to find a supplier of either board for my tv or yours.
hope this helps,
trin
Posted on Nov 18, 2007
Jul 01, 2011 | RCA HD52W59 HDTV Projection Television
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
Jul 13, 2009 | Samsung PCL5415R TV
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dec 11, 2008 | Mitsubishi WS-55807 TV
Jul 14, 2008 | Televison & Video
Jan 24, 2008 | Philips 55PW9363 55" Rear Projection...
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Jan 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Mar 10, 2007 | Mitsubishi WS-65819 TV
41 people viewed this question
