Question about Jwin JK-777 Nostalgic Stereo System with Turntable, CD Changer, Cassette Deck, and AM/FM Tuner Shelf System
Jwin/ jk-777 console drive belt broken
The drive belt on my jwin jk-777 console has dried and broken. I need a replacement part. Where can I go to get one?
2 Suggested Answers
  • 1606 Answers
SOURCE: Have had this JWIN model JK-777 turntable/am-fm/cassette/cd player unit. It won't power on now. Checked the outlet, no problems there. Does this unit have a fuse?
1. It's more likely the problem is a broken power cord or dirty power switch. If you've been in the habit of yanking the cord to unplug the unit instead of pulling directly on the plug, or somebody tripped over the cord, the power cord is probably broken right at the plug.
2. Changing a blown fuse without finding and repairing the fault that blew the fuse will only give you another blown fuse. It's not like the old farmhouse with too many things plugged in on the same fuse... A blown fuse in audio equipment is usually the result of a shorted speaker driver transistor. The transistors come in pairs; if one is bad the other has been overloaded and should be replaced also. That's a job for an electronic technician.
Posted on Nov 22, 2017
Nov 22, 2017 | Jwin Audio Players & Recorders
JWIN Model JK-777 won't power on. Checked wall outlet, no problems there. Does this unit have a replaceable fuse?
All microwaves have a main power fuse. You have to remove the outer cover. It will be located near the back by the power cord.
Nov 22, 2017 | Microwave Ovens
Jwin JK-777 How do you access the turntable belt?
Most turntables have an access point under the platter matt. The matt should peel up.
Nov 30, 2015 | Audio Players & Recorders
Jk-777 turntable belt
Take measurements of your old belt and then order one a tad smaller in circumference to account for the stretched condition of your belt and go to the following web site for belts. MCM Electronics Home and Pro Audio Video Security and Test Equipment
Oct 08, 2015 | Audio Players & Recorders
Kenmore dryer 110.66912690 .Does the motor shut off when the belt breaks? I know the drum can't turn, but the motor will not run. It just finished drying a load of clothes. Thanks
Yes it has a broken belt switch. This is a 4 wheel drive model. To replace the broken belt. The first thing to do is use your index finger to pop the shoulders off each end of the console. Place your finger on the top of the shoulder and pull towards you till it comes free from the control. This will expose the hold down screw on each end. Remove them next and flip up the console. 3 quarter inch hex heads screws must then be removed to get the top off. Once that is accomplished use a putty knife to release the base panel and remove it. Take care to see how the door switch wires go.remove the filter and filter chute. Remove the door springs then the yellow wire from the drum sensors. Remove the front panel, Remove the drum. Clean er up. My Video:
https://www.youtube.com/watch?feature=player_embedded&v=1VVNRfmbtEA
Dec 17, 2012 | Kenmore Dryers
Broken tines on honda tiller fr650 model need part numbers for left and right tines, or location near or in Concord NC I can purchase them.
I will supply you with the part no. I have:
06722-777-000 TINE KIT, ROTARY
72100-777-013 TINE ASSY., R. (OUTER) Use up to Frame SN 1021912.
72100-777-023 TINE ASSY., R. (OUTER) Use from Frame SN 1021913.
72150-777-003 TINE ASSY., R. INSIDE Use up to Frame SN 1021912.
72150-777-013 TINE ASSY., R. INSIDE Use from Frame SN 1021913.
72200-777-013 TINE ASSY., L. (OUTER) Use up to Frame SN 1021912.
72200-777-023 TINE ASSY., L. (OUTER) Use from Frame SN 1021913.
72250-777-003 TINE ASSY., L. INSIDE Use up to Frame SN 1021912.
72250-777-013 TINE ASSY., L. INSIDE Use from Frame SN 1021913.
Hope this helps. Make sure you verify the frame serial number. The tine assy. include the hubs and mounting hardware.
Feb 24, 2011 | Garden
CD Changer/turntable MDL Fisher DAC-145.
Hello....Give you local SEARS store a call and inquire...I've used them in the past...Their repair center does excellent work and repair more brands than anyone I know....If there are any up-front costs...they'll let you know...Try it and let me know....I hope this was helpful......PEACE.......
Feb 06, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Kenwood XD 550 stereo start-up problem
this normally happens with a lot of sets! It usually happens during a Power Failure, Power Surge (Fluctuation) and if the wire of the component is taken out from the wall outlet while the system is on...To get rid of this problem all you need to do is to press the Display button on the main unit, it is located just below the main display! Voltage Selection has got nothing to do with this problem...
Jun 29, 2008 | Jwin JK-777 Nostalgic Stereo System with...
Jwin model #JK-777
You will have to remove the cover shell and get the jam un jammed.I'll assist you if you need .
Jun 21, 2008 | Audio Players & Recorders
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
Jwin JK-777 Nostalgic Stereo System with Turntable, CD Changer, Cassette Deck, and AM/FM Tuner Shelf System Logo
96 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
