I have a Tappen furnace Model# SGUF 105 D30E7, I need to change it from nat. gas to LP, Where do I get A kit?
    President:
  • 2,777 Answers
Hello there,
A conversion kit definitely does exist for your Tappan furnace, you can find a dealer that sells the kit from this webpage, if I had your zip code I could find it for you, but head over here and pop in your zip code and it will find the closest one for you:
http://dealer.tappan.net/DealerLocator/Default.aspx
I tried to locate the exact model number kit you need but don't have it handy, the authorized dealer will definitely know based on the model number.
Thanks!
Tim
Posted on Jul 17, 2009
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
I need to change my heater form LP to Nat Gas Coleman evcon Model DLAS075BDF
You will need to change the orifices (part # 9951-1521) and, unless you can find a conversion kit for your current valve, your gas valve (replace with WR part # 36H32-304).
Sep 28, 2011 | Heating & Cooling
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
Want to convert heater from natual gas to lpg are jets available for this conversion.heater model no reh210ec thankyou
Dont know if you can get orvices for that heater but almost all gas appliances can be converted for nat to lp and lp to nat,they made a spud kit which is a blank orvice that you drill out your nat gas orvice to I think a 20 drill side and install the spud in and redrill to size usally a nat-gas orvice is around 8 to 10 sizes larger then a lp.The big thing is the gas valve and if it has a built in regulator or not,some valves can be conferted to open up the regulator pressure by the spring or a block off kit and others are fixed and cant be changed,have to replace valve.most nat-gas are at 3" to7" and lp is at 10".Hope this helps you
Jul 05, 2010 | Heating & Cooling
Looking to change heater3e239 to gas from lp what parts do i need
Contact graingers at grainger.com. Give them the model number and tell them you need a conversion kit from LP to Natural Gas.
Jan 19, 2010 | Dayton Gas Furnace Heater
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Propane conversion for cozy model CF503C
try national energy for a conversion kit they should be able to help or the will know some one who can
Jan 10, 2009 | Cozy CFR Utility Heater
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
