Question about Dehumidifiers
How to clean filter - Dehumidifiers
  • 250 Answers
The de-humidifier is a niche product. Its only job is to remove moisture from air to alleviate the problems of mould and mildew. It is very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance. This may be because it’s icing up, overflowing, not removing enough moisture, or simply time for a good cleaning to maintain its efficiency. If you don’t feel handy enough to attempt this project contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a frame and simply pops out. If no filter proceed to next step. If it is a disposable filter simply replace it with a new one. Other types are made in a plastic frame and can be cleaned and reused. To clean a filter lay it flat in the sink and sprinkle surface with powder laundry detergent. Plug sink drain and turn on hot water. Cover filter with enough water to submerge. Soak for 15 minutes. Remove from water and rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none proceed to next step. If there is resistance then look for hidden screws. If grille locks into cover proceed to next step. Once removed place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover screws may be difficult to see because are often painted to match body color. Usually two or three screws along each side of base. Once screws are removed lift the cover straight up. Use extreme caution at this point. Front grille may be secured to cover. Some fronts are put together like a puzzle. Parts often interconnect or are screwed to one another. If front grille lifts off with cover try to separate before proceeding. Front grille may lock into groove along front edge of cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil. They may appear as one but are actually two separate coils in very close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and rear surfaces of coils. Use an up and down motion to avoid bending fins. Area between two coils must also be cleaned. Use caution, the fins are soft aluminum and can be easily damaged. Once surface dirt is removed, spray with de-greaser or light cleaner. There is a good product on the market called HVAC cleaner. As the name implies it is meant for Heating, Ventilation, and Air Conditioner coil cleaning. If this is not available Fantastic Spray cleaner used in kitchens and bathrooms works quite well. Remove dirt and excess cleaner by slowly pouring warm water into fins. Do not allow the water to enter any electrical connections or components. As an added precaution cover the motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor for oil holes. Add a few drops of oil to each end of the motor body. Use a general purpose (3in1) oil or clean motor oil. A #30 oil is sufficient. Three or four drops on both ends of the motor body are sufficient. Add the oil slowly, pausing a few seconds between each drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin comb then use something soft such as a Popsicle stick. Straightening the fins will increase the efficiency of the airflow through the coils. Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly. Vacuum underside of metal cover. Vacuum dirt buildup from base and any other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models testing may require temporary override of bucket overflow switch. Test that cooling coil begins to sweat water within few minutes of operation. If everything appears okay unplug and reassemble. Insert water collection bucket slowly to avoid damaging float switch mechanism.
Posted on Jul 17, 2009
How do you clean the air filter?
The cleaning of Dehumidifier Air Filter is very simple, Air Filters are washable. Just remove the backside part of the device and take out the air filter. Wash it with water and fix it.
https://www.vackerglobal.com/divisions/dehumidifier-humidifier/desiccant-dehumidifier/
Feb 20, 2016 | LG Dehumidifiers
Clean filter light wont go out and i cleaned the filter
Did you clean the sensor to? I think that will help a lot.
Jan 19, 2015 | Dehumidifiers
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
Removing the filter model fdl7051
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
Aug 12, 2014 | Frigidaire Dehumidifiers
How to clean the filter
Good Afternoon Tad, thank you for allowing me to assist you!
First remove the bucket to reach the filter of your Frigidaire dehumidifier, FAD504DUD. When you locate the filter, pull it downwards. The filter can be clean by either washing it with clean water or using a vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once the filter is reinstalled then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier will resume normal operations.
Hope this helps!
Jan 31, 2014 | Frigidaire Dehumidifier Fad504dud
Dehumidifier smells stinky
Have you read its manual? http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
It says (p8):
Care and Cleaning
1. Filter
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, then replace Bucket.
2. Cabinet
a. Dust cabinet with an oil-free cloth, or using a damp cloth.
b. Vacuum grill using brush attachment.
3. Water Bucket
a. Clean bucket with warm water and detergent.
I recommend you to use a mix 75% water, 25 % vinegar. To clean its water bucket.
Oct 01, 2012 | Frigidaire FDF70S Dehumidifier
How do I access the filter on my LG (LHD659EBL) dehumidifier, how do I clean the filter, and how often should it be cleaned?
To find and remove the filer. First, turn the unit OFF & unplug it. Then remove the water bucket. The filter frame & handle will be located at the top of the bucket holder just behind the front louvers. If you have never removed and cleaned the filter, it may have a piece of plastic tape on it, which was used for shipping. Remove the tape & discard it. Pull the filter frame's tab handle straight down and remove the filter. It can either be vacuumed or if it's really dirty, washed in warm water and a mild dish washing liquid. Rinse thoroughly and shake off any access water. Allow it to dry completely, before reinstalling it. Never operate the unit without the filter in place. Doing so could cause damage to the unit.
Clean the filter at least once every two weeks.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | LG LHD659EBL Dehumidifier
The filter is getting ice on it when I turn it on.
If you haven't already, clean the filter after it has thawed. In addition, the coils behind the filter may need cleaning.
Turn the unit OFF & Unplug it. Remove the filter and the upper half of the front of the cabinet. Clean the cools with warm water and dish washing liquid. Rinse with a damp sponge, dry the coils and apply a light coating of WD40. Reassemble the cabinet, plug the unit in, turn it back ON and take it for a test drive. Be sure to clean the filter at least once every 2 weeks.
Jul 19, 2011 | Whirlpool AD50USS Dehumidifier
Hi Fixya: The Filter on my Danby DDR7009REE Room dehumidifier never seems to accumulate any dust. It is supposed to need to be cleaned every two weeks by vacuuming or soaking, but the filter is always...
How often does the unit run? Does the fan run when the unit is suppose to be running(as the fan pulls the air thru the filter). If every thing operates correctly and the filter is in the right location on the unit then all I can say is that you keep a clean house. Personally I only need to clean the air filter on my dehumidifier about once a summer. I wouldn't be overly concerned if it isn't getting very dirty.
Nov 10, 2009 | Dehumidifiers
Should I clean or replace the air filter?
You can wash the filter with water, no problem. However, I would recommend replacing the filter every 3 to 4 months depending on how much you use the dehumidifier. The exposure to constant moisture will cause the filter to grow mold over time.
Jul 27, 2007 | Amana DK25 Dehumidifier
Dehumidifiers Logo
634 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
