ONLY HD2 works, which is used most of the time.
On my Toshiba 65h80...ONLY HD2 works, which is used most of the time. Rest of TV, Video 1,2&3 and HD1 hardly used doesn't work any more.
  • bhupesh_g Jul 19, 2009
    I al ready have checked that... and it is NOT locked. If I turn off the TV completely from the main line (complete reset) for 3 or more minutes, it starts working and then goes bad. HD2 works just fine without any problem. When other channel (TV, Video 1,2&3 and HD1) work they look good.
    Thanks for the reply.
    _Bhupesh_g
    I did check it out before posting and it is set to OFF. If I turn off TV for 3-4 minutes by removing the plug from the wall... it comes back ... works for while then goes bad again. HD2 works just fine. Other channels when work looks fine.
    Bhupesh_G
  • 668 Answers
I would look to see if a set up menu on the set has the other inputs lock out.
Posted on Jul 18, 2009
How do I start what dose the tv have to be on tv
Neither HDMI ports. The wii can only be hooked up via AV or Component cables.
Sep 21, 2013 | Nintendo Wii Console
We lost picture (no picture) through cable portal. Tv has blurred picture using HD wire connection via HD1 & HD2 Portals. As tv warms up picture slowly clears. The problem has progressively gotten...
hyperunit failure. that tv uses whats called a " next hyper-unit" it is the digital scan card for the tv. it does the video and audio processing for the tv. they can be very heat sensitive and get better ot worse over time. the repair is very involved i suggest calling a repairman.
Dec 22, 2010 | Toshiba 57H82 57" Rear Projection...
Not sure what channel tv needs to be on for dvd player
DVD usually goes to the Audio Visual ports, usually Red Yellow and White. OR Component Video, Green, Blue, red. Select it via AV.
Jan 26, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
No picture, no sound, but has power light...any suggestions? thx in advance
Do this first:
1: Check the antenna/cable connections.
2: Press the TV/VIDEO on the remote control or the TV to view a signal coming from another device connected to your TV, such as a VCR or
video disc player. You can select ANT 1,
VIDEO 1, VIDEO 2, VIDEO 3, ColorStream HD1, ColorStream HD2, or ANT 2 depending on which input jacks are used for connecting the devices.
*Be sure you have the right source to view video.
Try the above and post back before I can say there is a problem with your unit. If you have the user manual it's a good time to get it out. If you don't have it let me know and I will give you a link to obtain it. Good luck!!
May 23, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba TN55X Convergence problem.
You brought up an issue that we hadn't considered. Shortly after hooking up our TV to the receiver with a composite video, our convergence which wacko. My hubby replaced the 2 ICs, but now our power button just flashes red, with no picture. Not sure if new ICs are faulty or if it's another issue. He will replace old ICs to see if problem still exists with turning on the tube. And he'll try disconnecting the video signal to see if problem exists.
Ouch.. may have to consider another tv thanks to new technology ??????
Good luck solving your problem.
Jul 06, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
Get sound but no picture
Plug the yellow RCA cable into the Video Out on the 3 2 1 and into one of the Video In ports on the tv. Make a note of which port you plugged into. Then change the input selector to that video port on the tv.
Feb 16, 2008 | Bose 3 2 1 GSX System
Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
Dec 07, 2007 | Sanyo Xacti HD1 Memory Card Camcorder
Televison & Video Logo
Top Televison & Video Experts
