Question about Printers & Copiers
  • 1,006 Answers
Re: HP PSC 2355XI
If my solution was helpfull rate this as FIXYA please
Posted on Nov 18, 2007
0 characters
3 Points
HP PSC 2355 error
Hi Brown3377;
when you install the HP Software, what selection did you choose? is it the recommended or custom settings? maybe you missed the scanner driver for your printer that is why it says you need to install it first. you can insert your HP cd and check it out, click custom install and double check to see if you have the scan driver selected, if not, select it then install... then try to remove the printer usb cable, reboot your printer and computer.
Jun 24, 2008 | HP PSC 2355 All-In-One InkJet Printer
How do i connect my hp psc 2355xi to my computer?
If you have already downloaded your software for the HP 2355XI or put the software from CD to your computer then your computer should recognize the new software. If you need the software go to HP and enter model and search software then download to desktop and follow directions. If by chance the default printer is set as Microsoft you need to click start then control panel and choose printers and take Microsolft off default and add HP 2355XI by right click and set as default printer. That should solve your problem. Sea Breeze
Aug 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
After upgrading to a new computer with Vista, the ocr not working
Check the HP web site and see if they have an updated driver for your AIO printer that will work with Vista
Mar 19, 2009 | HP PSC 2355 All-In-One InkJet Printer
Installing the software
Nov 15, 2008 | HP Photosmart 2410 All-In-One InkJet...
Cd software does not like vista?
updated the printer driver. click here to download
hope this'll help you
Nov 06, 2008 | HP PSC 950 All-In-One InkJet Printer
Printer not working
Hi blesko6-
Here's a starting link to try from HP's support site for your model:
There are 4 models to choose from listed there:
HP PSC 2350 All-in-One Printer series s.gif s.gif s.gif » HP PSC 2355 All-in-One Printer
» HP PSC 2355p All-in-One Printer
» HP PSC 2355v All-in-One Printer
» HP PSC 2355xi All-in-One Printer
HP's support site drills down to your specific model first, then starts answering support questions. If you're not sure what your model is, you can usually just click on the first model in the list and start getting answers. Hope this helps.
Nov 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Trying to re-install my hp psc 2355 & get errors
please try plugging the printer if it detected by PC. if it is detected maybe you need to update the driver of your pc. Please install the updated driver or reinstall the drivers of your system and then reinstall the printer software after rebooting. Disable the antivirus and other annoying program.
If this not solve the problem, please try download an updated driver from the hp website.
or here:
pls donot rate me if this not solve the problem, notify me if you need more solution.
Apr 09, 2008 | HP PSC 2355 All-In-One InkJet Printer
Printers & Copiers Logo
90 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
