Question about PfaFF Creative 7570
My bobbin mechanism has stopped turning on both a 332 and 1222E - thereby locking up the machine - is there an fix that I can do myself?
  • 632 Answers
Is your presser bar lever all the way up to the 2 o'clock position? If so you are in "StopMatic" mode which is for bobbin winding. Place the presser bar at the 3 o'clock position to engage the machine for operation.
Posted on Sep 15, 2009
Bobbin case keeps popping out
Hallo Rhonda
Pls chk your bobbin locking at fixing shaft grew or not. on bobbin a sliding locking plate locks at shaft. while keeping in case chk that is loked by pulling. if it dosent lock , change bobbin with spare one.
Jul 16, 2014 | White Sewing 2037 Mechanical Sewing...
My machine started making noise and the handwheel became hard to turn. The hand wheel stopped turing completely. can I fix this myself or does it have to be repaired professionally?
Take the bobbin case out completely to begin witgh and check for any jammed thread, see if you can turn the balance wheel once the bobbin case is out, if you have a front load bobbin take the raceway out as well, if it still does not move you have a problem which will need shop attention
Sep 05, 2011 | Singer 2263 Mechanical Sewing Machine
Sewing slowed and then stopped
If you are unable to move the wheel then something is locking up the mechanism.
Please try removing the bobbin and the bobbin case and try turning the wheel.
If the unit does not jam, try reinserting the bobbin and the bobbin case. You might need to consider replacing the bobbin case if the unit jams again.
If it still jams without the bobbin case in, then the mechanism might be broken and you should bring the unit to be looked at by a brother tech. Brother techs will look at the machine and diagnose the issue free of charge and will only charge you if they have to do any out of warranty repairs.
Thanks,
Pat
May 12, 2010 | Brother CS-80
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
Bobbin not turning, possible motor/gear issue?
You have a broken vertical shaft gear. It's very easy to replace if you are mechanically inclined. The gear can be purchased for between $8-14 from a sewing repair store and I can walk you through the process.
Jul 19, 2009 | Sewing Machines
Thread is not coming up from the bobbin assembly on sewing machine. Stitches don't show any thread coming from the bottom.
YOUR PROBLEM IS THE TIMMING IN YOUR MACHINE. THIS HAPPENDS WHEN YOU FORCE YOUR MACHINE TO SEW SOMETHING OR WHEN YOUR NEEDLE BRAKES. nOT SURE HOW TO FIX IT. I HAVE THE SAME PROBLEM. USUALLY A TUNE-UP WOULD DO IT. IT'S ABOUT $99 TO $130.00 TO DO A TUNE UP. i WISH I KNEW HOW TO FIX IT MYSELF.
Oct 01, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
235 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
