Question about Maytag Washing Machines
My washer won't turn on, I checked circuit breaker and plug. Model # MAV4758AWW
  • 525 Answers
Below is information provided by www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams.
You may also find this to be of assistance;
http://maytag.custhelp.com/app/answers/list
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Jul 17, 2009
Dishwasher will not start
Make sure all the little doors and lids on the inside are properly shut. Make sure the main door is properly shut and the latch has caught properly. Make sure the power and water are on. Switch the power off and on at the socket just to make sure the controller is not locked up.
Nov 02, 2017 | Dishwashers
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
It won't turn on
check the electrical outlet and, or, the circuit breaker to your washer
Feb 04, 2013 | Miele Novotronic Premier 500 Front Load...
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
My LG washer won't power up
Double check the cord to make sure all the wires are hooked up to the washer correctly, check your breaker/fuse box to make sure you don't have a tripped breaker or blown fuse, and check the outlet for power by plugging a known working item into it or using a circuit checker.
If the washer is getting power, try holding the power button down(if there is one) for 3-5 seconds.
If that doesn't help, here's a link to LG's customer support options: http://www.lg.com/us/support/contact-customer-service
Feb 09, 2012 | LG Washing Machines
My whirlpool washing machine sm8525079 won't turn on? not a circut breaker problem?
If I am understanding your posting correctly- a circuit breaker tripping is a result of a washer fault rather than a fault with the circuit breaker. Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 06, 2011 | Washing Machines
My washer will only work on the cold setting. turned off the hot and cold valves and turned them back on. I also threw the breakers...still no change. Any ideas? Can I repair myself?
The problem is the water inlet valve is either clogged up or has failed. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru testing this it's a different model but testing procedure is the same. Try cleaning out the screens before disassembling and check the screens in the hoses.
Mar 28, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
Washer won't turn on
Begin by checking to be sure the outlet where you have the washer plugged in has power. you may have blown a fuse or popped a circuit breaker. If no power, either replace the fuse or reset the circuit breaker by turning it all the way off and then all the way on.
Feb 28, 2009 | Washing Machines
Washing Machines Logo
202 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
