Question about Nokia 2600
The screen to our Nokia 2600 is frozen as it the entire phone. Wall paper shows up but phone does not work or respond
What is the unlocking code for Nokia 2600c-2b Imei: 011667002906793, locked to AT&T USA??
Your Nokia Unlock Codes!
Please do read the ENTIRE PAGE prior to attempting to enter your codes
Nokia Unlock Codes Generated For Nokia 2600
These Nokia Unlock Codes are Generated For Nokia 2600 with IMEI: 011667002906793 (DCT 4) Locked to ProviderAT&T(Other DCT4) in U.S.A. and will only work with this phone!
#pw+754440272246356+1#
#pw+354116772233126+2#
#pw+746320766415330+3#
#pw+288055103672167+4#
#pw+396496413416000+5#
#pw+837921656511136+6#
#pw+237225755524034+7#
How to Enter your Unlock Codes
Recommended CODE :#pw+237225755524034 +7#
  1. Remove SIM CARD !
  2. Type #
  3. Then press the * key 3times (you should get a "p")
  4. Then press the * key 4times (you should get a "w")
  5. Then press the * key 2times (you should get a "+")
  6. Then enter: 237225755524034
  7. Then press the * key 2times(you should get a "+")
  8. Then enter: 7
  9. Enter: #
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
  • If you get CANNOT UNDO RESTRICTION your phone cannot be unlocked remotely and you need to mail in your phone!
  • If you get CODE ERROR the above codes do not work for your phone DO NOT ATTEMPT TO ENTER THE SAME CODE AGAIN
    Repeat above instructions, but with the numbers from code 1 (#pw+754440272246356+1#) if code that does not unlock your phone STOP! . You need to Mail-In your Nokia phone to have it unlocked
Nov 27, 2012 | Nokia 2600 Classic Cell Phone
Touch screen frozen
Did you try to pull out the battery and restart your phone? If not try it, if yes and it's still not working, you have to go to a service point to do the job for you.
Jan 28, 2012 | Nokia N72 Cellular Phone
When i apply theme on my nokia 2600 classic every effect comes except the theme's wall paper .can u solve this problem????
Restore Factory Setting.hints:setting>>Restore Factory Setting>>click OK and enter security code the default code is 12345,You are done .Good luck
Jul 25, 2011 | Nokia 2600 Classic Cell Phone
How to add phone #s to sim card screen do not work
press center (menu) then down 3 times press center 2 times ,click center then type number then ok
Jun 01, 2010 | Nokia 2600
When i insert sim ,a message appear on my 2600 nokia phone screen : "security code:" .
Hello.
The code your nokia 2600 need is 1 2 3 4 5. to star operation .If it fail it means that someone or you have change the code. Then the other way out it that you should take it to a work shop for a flash then your phone will work has it expented
Mar 12, 2010 | Nokia 2600
Nokia 2600 classic no sounds
the speaker may be not working so you need to change the speaker and check it
Oct 03, 2009 | Nokia 2600
Nokia 2600 is not showing network
in nokia 2600, sim active but no signal and no network coverage.
Apr 26, 2009 | Nokia 2600
Wall Paper in full screen
Hi, I am using Nokia N73 music edition. I want to know Can we have Wall papers to come as full screen when applied as the wall papers, instead of what it comes as i.e, in standard size.
Jun 02, 2008 | Nokia N73 Cellular Phone
Nokia 2600
I have nokia2626 cell phone how i connect the phone with PC..? please reply ro me.
Apr 10, 2008 | Nokia 2600
Nokia 2600 Logo
69 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
