Question about HP J3680 Officejet All In One Printer
Where do I find the serial # on my printer? - HP J3680 Officejet All In One Printer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Underneath
Posted on Jul 17, 2009
Need serial interface for this printer
The option of serial printing is not available in t 2240 printer . One thing you can do is to use serial to parallel converter through your PC/LAPTOP to printer. If you are using PC you can add a pci serial/parallel card also. For laptop there are usb to parallel converters available in the market. try the following link for it
. http://www.directron.com/cables---adapters-printer-cables---adapters.html
Dec 27, 2012 | Tally T2240/24 Matrix Printer
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
Where can i find the serial mumber on my canon pixma mp495 printer tried all on bottom
PIXMA Printers and All-In-Ones
The serial number is located inside your PIXMA printer. To find it, open the printer lid as if you were to access the cartridges tray: the serial number is printed on a white sticker. Be careful to not confuse this number with the power supply serial number that can be found on the bottom of your printer.
Hope it helps.
Apr 26, 2011 | Canon PIXMA MP495 InkJet Printer
Which port should I use for my printer: com 4 serial port com 6 serial port com 8 serial port usb virtual printer port
depends how your printer connect
if you realy are connecting an old serial printer com1 or com2 should be fine as long as you do not have a mouse or a modem on them ...
if USB any port is fine
if parralel printer you are only likely to have one...
Mar 18, 2011 | Computers & Internet
Hi i bought a Z4mplus.. I have a laptop that only has usb ports and have connected the zebra with a usb - serial converter... however the computer installs the printer driver but wont send any information...
Make sure the serial port parameters match between the printer and the usb-serial driver. The Zebra printer is usually set to 9600 baud, 7 data bits, Even parity and 1 stop bit. The serial driver is probably different. The mismatch will prevent communications.
Hope that helps !
May 06, 2010 | Zebra Z4Mplus Label Printer
About serial key
Details Issue: Where is the serial number located?
Solution: Locate the serial number MP150
topFrame=findTop(this); Locate the Serial Number The serial number of the PIXMA MP150 is located inside the printer, as shown below.
  1. With the printer powered on, lift the scanning unit and pull the scanning unit support down into place.
  2. The serial number is attached to the back wall inside the printer.
    It starts with four letters (JCBA, JCBB, JCBC or JCBD) and ends with five numbers. Example: JCBA01234, etc.
.footergray { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: none; font-weight: bolder; } .footerblack { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: underline; font-weight: bolder; } © 2008 Canon U.S.A., Inc. All rights reserved. Duplication in whole or in part without permission is prohibited.
Jan 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Can't find the serial number on my Canon iP1800 printer
Please remember to rate other users who assist you for free :)
Locate the Serial Number When confirming the serial number, ensure that the printer is POWERED ON before opening the top cover. The serial number of the printer is visible when the top cover is opened, as shown below.
The serial number starts with four letters and ends with five digits.
(Example) VVPP00018
Sep 30, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
There is a serial port besides the parallel. how can i make it work with serial cable?
if the printer is built with a usb port, the it should work, is there another USB device in the PC that is working ?
Jun 02, 2007 | OKI OL 400e Led Printer
OKI ML280 serial card installation
I believe on the top of the printer towards the back is a panel with a single screw. Under here are dip switches to set the printer.
Jun 18, 2006 | OKI (09002353) Serial Adapter
HP J3680 Officejet All In One Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
