We start the washer water fill up but dont agitate
  • Dale Staggs
    Dale Staggs May 20, 2016
    it does everything but agitates
  • Jason Harris
    Jason Harris May 20, 2016
    Sorry it's not your motor I have found a video so you can see what the problem is and how to change the parts that have worn ok it's a utube video copy and paste this in utube and watch ok hope I have helped youhttp://youtu.be/7CM2UVKb_T4
    Sergeant:
  • 274 Answers
This sounds like your motor brushs have worn down to the point where they need replacing ok
Posted on May 19, 2016
  • Dale Staggs
SOURCE:
Kenmore 800 washer agitates before filling with water
This could be caused by a couple of problems. The water level sensor could be bad so that the washer thinks it's got water in it already or the timer could be bad. If the washer starts to fill after it starts agitating then the timer would be the problem.
May 30, 2014 | Kenmore 24032\24036 Top Load Washer
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
Machine fills up with water then when its suppose to agitate it just stops working will turn timer & push knob in & out & reset then it will work
How long do you let it sit after the water fills up, somtimes the timer will take a little extra time to get to the point that starts the agitation cycle.
When it dose this, without pulling the knob out, turn the disk on the timer clockwise 1 click and see if it starts up agitating, if it dose dont worry about it it is normal
Nov 09, 2009 | Maytag PAV2300 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer fills up but won't agitate
get your screw driver and lets start.. first unplug the machine from the outlet, you have to access the water level sitch so remove the tab and there is the bandidt, knock him with the screw driver and if this not funcion replace it..good luck I dont tell you to check the thin hose in the water level sitch becouse you said its fill all right.
Aug 06, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
