Question about Sony NWZ-B103FBLK MP3 Player
My NWZ-B105F goes on (battery full) but when I press the play/pause button to activate ANY option (e.g. Music Library), the player shuts off. When connected to the USB port it says "USB Connect" but I cannot access the unit (e.g. can't copy an mp3 file to it). Also, I tried updating the firmware but it looks like that routine cannot "find" the Walkman. I've tired to reset it numerous times with no positive result. Sony tech support in an on-line chat told me "it has an internal malfunction." lol Thanks.
    Problem Solver:
  • 4 Answers
There was a solution posted to this problem which I used successfully. In addition, I posted my comments that provided some additional information. I hope it all got posted. Thanks.
Posted on Jul 18, 2009
My mp3 player can not start
hi elada2005,
check if the new battery is placed in right polarity \-. Often it goes on when you hold on the "play" button for 5 sec.
what is that for model?
Jan 08, 2012 | Sony Walkman NWZ-B105F MP3 Player
Dear sir, when i turn on my nwd b105f walkman, it is swhowing that' boot error, shutting down'. it was functioning smoothly before and i tried to delete the songs and formatted. this error happened after...
This issue may occur if the portable player was formatted via Windows Explorer. Follow these steps to correct this issue:
NOTE: If the message you receive is Format OK? , select Cancel .
1. Connect the player to the computer.
2. Click Start and then click My Computer .
NOTE: If the Portable Device box appears, click Cancel .
3. In the My Computer window, under Other , double click the icon for your portable player.
4. In the My Computer [Name of your device] window, right click the Internal Storage icon and then click Format from the menu.
5. In the Format box, click OK .
6. In the Format Complete box, click OK .
7. Close the My Computer windows.
8. Disconnect the portable player from the computer.
9. If it is not on, press the power button to turn it on.
10. Press the selector button repeatedly until Settings is highlighted.
11. Press the Play / Pause button.
12. Press the selector button repeatedly until Format is highlighted.
13. Press the Play / Pause button.
14. Press the selector button one time to highlight OK .
15. Press the Play / Pause button.
16. Once the player has finished setting up, Music Library will appear in the display and you can now use your portable player.
17. Test the player for proper functionality. If the error still occurs, reset the player by pressing the RESET button with a small pin or similar object.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Thanks for using FixYa.
Mar 10, 2011 | Sony Walkman NWZ-B105F MP3 Player
Nwz-s639f stuck on hold
try reseting it if theres a way you can. or if theres a hold button
Sep 03, 2009 | Sony Walkman NWZ-B105F MP3 Player
Sony NWZ-B105f shuffle repeats same songs after start up, does not pick new songs.
Press and hold the Reset button for 30 seconds then try playing the songs. If the issue persists then format the walkman then reload all the musics and try playing back.
If the issue persists even after performing all the above mentioned steps then service is required.
Follow the under mentioned steps to format the Walkman:
Press and hold the Back/Home button in the Pause mode until the Home menu appears.
Press the up/down/left/right button to select Settings, and then press the >|| button to confirm.
Press the up/down/left/right button to select "Common Settings," and then press the >|| button to confirm.
The list of "Common Settings" options appears.
Press the up/down/left/right button to select "Format" and then press the >|| button to confirm.
"All data including songs will be deleted. Proceed?" message will appear.
Press the up/down button to select "Yes," and then press the >|| button to confirm.
"All data will be deleted. Proceed?" message will appear.
While the memory is being formatted, an animated display appears. When initialization finishes, "Memory formatted." message appears.
Aug 24, 2009 | Sony NWZ-B105FWHI / NWZ-B105FBLK MP3...
Shuffle option on SONY NWZ-438F
When you are listening a music, press the "OPTION BUTTON", and after enter in "PLAY MODE". There you will change the play mode of the MP3. Good Luck.
Feb 12, 2009 | Sony NWZ-E438F Digital Media Player
My sony Mp3 is not working
I tried something and it seemed to work ( though how long it will lst I don't know ).
1. Let the battery go dead
2. Put the player in the USB port
3. Update with latest Flash Driver ( check the format option )
4. When finished, remove from the USB port WITHOUT disabling the port through Windows ( just pull it out )
5. Hold down the play button and keep it held down.
6. Navigate to Settings.
7. Go to Restart option and click ok. You have to be quick here since you have to release the Play button. Once you get to the next level , keep the play button pressed or else it will shut off
8. Once it says restart is complete, press power button to shut it off.
9. If you have enough power, give it a try otherwise plug it back in USB port for about 5 to 10 min to get a charge.
10. Remove from USB port the same way as before.
Nov 29, 2008 | Sony Walkman NWZ-B105F MP3 Player
It has frozen on the options screen where you can choose music/radio etc
Simply by pressing the reset button fixed the 'freezing issue'
Oct 14, 2008 | Sony Walkman NWZ-B105F MP3 Player
HELP ME PLEASE with my "sony walkman NWZ-B105F MP3 PLAYER."
make sure your downloading it to the right folder on the mp3 player its usualy the music folder or you can try and use windows media player here are some instructions for that option.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Apr 12, 2008 | Sony Walkman NWZ-B105F MP3 Player
Creative Zen V
ok
from the main music screen hit the back button until you see all the option listed below...
music library
now playing
photos
videos
FM radio
extras
system
go to system
go to player settings
go to idle sleep
push in the middle button
and select off
im a drummer 2 so i understand how annoying that can be
Mar 24, 2008 | Creative Labs ZEN V Plus MP3 Player
I need help adding music to my sony walkman
it's the 4GB NWZ-A816PNK Walkman version?
connect usb to your computer
wait for the connect sound
open my computer
look for removeable drive
right click on it and explore
go to music folder
open your library
drag w/e songs u want into the music folder
dc, turn on. browse and play. hope this helps.
Feb 23, 2008 | Sony NWZ-A816 Digital Media Player
Sony NWZ-B103FBLK MP3 Player Logo
132 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
