Question about Hotpoint WMA50 Front Load Washer
Top loader I have a portable washing machine, when it spins it leaks from underneath the washer.Thanks, Marion
  • 76 Answers
I would check around the door seal see if there is a hole in it, it will probably be around the side somewhere.
Posted on Nov 18, 2007
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Hoptpoint Washer Dryer - rattling noise and leak from underneath
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Leaks when the washergoes into the spin cycle.
Could be crack on underhose or possible drum fault
Sep 30, 2009 | Roper RAS6233KQ Top Load Washer
Hotpoint WMA50 Front Load Washer Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
