Hitachi 53UDX10B 53 in. Rear Projection Television
Problem for Hitachi 53UDX10B 53 in. Rear Projection Television
Red gun appears to be smearing. Magic Focus
By skefboomer on Jul 17, 2009
Red gun appears to be smearing. Magic Focus doesn't help. Horizontal displacement of every other line to the right on the red channel. Tried other input sources to eliminate possible cable failure.
Solution #1
posted on Jul 22, 2009
Not Rated)
Ecollier2012
Rank: Guru  Hitachi Expert
Rating: 93%, 558 votes
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 53UDX10B 53 in. Rear
Questions and Unsolved Problems for Hitachi 53UDX10B 53 in. Rear
Do you recommend Hitachi 53UDX10B 53 in. Rear Projection Television?
Answer
Answer
My has lines running across it after I turn it on for a few minutes. Usually if you shut it off and... (More)
Answer
When i turn the tv on the pitcure is all scribble it has a
Answer
Lately when I turn my Hitachi 53udx10b UltraVision (rear projection) on my yellow color seems to be... (More)
Answer
tv powers up , picture flickers, but does not stay on model 53udx10b
Answer
We are experiencing yellow spots on our Hitachi 53UWX10BA tv which is about 6 years old. Please let... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
