The frame posts aare suppose to sit on the stoppers and the instructions say to push down until firmly in place, but when I put the post on the stopper they are wobbly
SOURCE: Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
SOURCE: Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
SOURCE: stopper came out Pegasus bathroom sink
Pegasus make several models but I'll make an assumption that it has a pop-up plug actuated by a rod just behind the tap head.
If correct....
Under the sink in the cabinet you will see the rod comes down and connects to an adjustment fitting and into the main drain line from the sink. There will be a fitting on the drain line holding the connection. Inside is a metal ball and connecting rod that links to your plug.
Remove the fitting.
Slide the ball and rod partially out.
Put your plug back in.
Engage the rod again (you will need to fiddle a bit here).
Tighten the fitting.
Run water to ensure the fitting is tight and not leaking.
Should be good to go.
Please rate this answer if it gives you some direction.
SOURCE: Jenny Lind crib instructions...
Jenny Lind is a style of crib, not the mfg
DaVinci makes Jenny Lind...
http://www.milliondollarbaby.com/instructions
If you find your model, go to the Customer Care and click order parts
