Question about Waring WMK300 Professional Belgian Waffle Maker
Waffle iron light is on but doesn't heat up
I have the same problem as posted on here. The light comes on and it doesn't heat up. This is after one year of use. Is there a solution or do I have to buy another one?
  • 1 more comment
  • stellaluna Dec 25, 2007
    My Belgium waffle maker heated up the first time. It made 2 waffles, then it would not heat up again. I took it back and exchanged it, my new one did the same thing. It turns on as far as the orange light, but it does not heat up, and the blue light does not come on. Are these worthless?? It's a little costly if all you get is 2 or 3 waffles and then the machine is done. Please help me with this problem.
  • Anonymous Aug 15, 2008
    WE UNPLUGGED IT AND PLUGGED BACK IN TO "RE-BOOT" BUT IT DID NOT WORK. IT JUST QUIT, IN THE MIDST OF COOKING A BATCH OF WAFFLES. WE HAD IT LESS THAN 8 MONTHS. USED ONCE OR TWICE A MONTH DURING THAT TIME. IT JUST QUIT HEATING UP, THOUGH THE LIGHT WAS STILL BURNING. NOT WORKING
  • missmelissa7 Feb 21, 2009
    I have this same exact problem!!! and truly no technical skills to fix it!
    What a waste of money!!!
The same thing just happened to my waffle iron. It worked great for a few months and then no heat.
I took it apart and found the problem. Waring used a thermal fuse instead of a thermostat. The fuse is located between the waffle iron and the stainless cover. The issue I saw is that cooking oil (spray) gets in between the cover and griddle and soaks into the insulation covering the thermal fuse. The oil heats up inside there and shorts the fuse.
Replacing the fuse is easy and it is available at Radio Shack for $1.70 (part number 270-1321). It's a 442 degreeF.
The hard part about this job is diassembly and reassembly. I had to take the entire iron apart just to get to the fuse. It took about an hour to take apart and an hour to reassemble. Changing the fuse took 5 minutes.
Good Luck,
Jim
Posted on Mar 21, 2008
Jim's advice worked perfectly. We went to Radio Shack and bought the part and the waffle iron works perfectly fine now. Thanks Jim!
Posted on Aug 17, 2008
2 Suggested Answers
  • 27 Answers
SOURCE: waffle iron light goes on gut does not heat up...
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
Posted on May 25, 2010
I have a green light and a red. what do they mean?
Red means that it has power. Green means the heating element is on. The green light will cycle on and off as the thermostat controls the temperature. Allow the iron to heat til the green light goes off before adding batter. Watch for steam coming from the iron. When the steam stops the waffle should be done. Keep track of the time that it takes to cook. Experiment with cooking time for the best results.
May 09, 2014 | Toastmaster 277 Belgian Waffle Maker
Waffle iron not heating
see this steps and fix it. God bless you
f the appliance does not heat, make sure that power is on at the outlet and test the electrical corrd , replace it if needed. If this doesn't work, disassemble the unit and test the heating elements.
If the appliance does not heat to the proper temperature, check the thermostat contacts. Some cooking appliances have an adjustment to reset the temperature ranges; you'll need the owner's manual to do this job.
Oct 15, 2012 | Hamilton Beach 26500hb Waffle Maker...
The waffle maker has two lights. A red one which indicates te power is on and a green one which lights up when it reaches the desired heat (and the thermostat circuit opens and the device stops heating...
There seems to be a problem with your thermostat or temp cutout switch if the machine is getting exceptionally hot. This could explain the green light not coming on.
Jan 26, 2011 | Krups FDK2 Waffle Maker
Why does my waffles stick?
You have to lightly coat the waffle iron with vegetable oil, and then you won't have them sticking.
Otherwise, it's a mess!
Dec 12, 2010 | Toastmaster TMWB2BELW Waffle Maker
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
Waffles stick to both sides of iron
Lightly oil iron prior to heating it up. Use 2 Tablespons of oil in recipe.
Apr 06, 2009 | Kitchen Appliances - Others
Over heating
I would try a new thermostat. I have seen these go defective. Callt he manufacture rep for any spare parts information.
Jerry G.
Jun 22, 2008 | Salton WM5ABLK Waffle Maker
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
Waring WMK300 Professional Belgian Waffle Maker Logo
1,387 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
