How to remove recycle virus?
I have tried all autorun remover software, but due to yhe presence of recycler virus it again appears when we insert any removable disk like pen drive,memory card...it just display autorun detected. i use quickheal total security antivirus. plz giv me solution to remove the recycler virus. thank u..
    Brigadier General:
  • 10,406 Answers
Access: http://cainternetsecurity.net/entscanner/
and do a scan of your computer, and then click "remove" when the scan is done.
Posted on Jul 17, 2009
My PC has been affected by RECYCLER virus.......................Please tell me how to remove the virus? It is urgent!!!
You can use combo fix from save mode
http://combofix.net/
Follow the step.restart the pc >press F8> select save mode use the down arrow key .copy and paste the combo fix and dubble click on it and wait for few minutes. If you can not entry in save mode do the following steep bellow
>download the
Kasperky=http://www.filehippo.com/
Please install the kaspersky and scan with kasperky antivirus, it will solve the problem. kaspersky will delete the virus apliacation, then you have to follow this steps. 1- Go to Wondows Explorer/Tools/Folder Options/View/ and uncheck "hide protected operating system files"
when youn will delete just drag the file and delete, dont dubble click on the recycler and autorun .inf.
2- now look for the folder "RECYCLER" in your hard drive'spartitions and and delete it (don't wory about delete it, windows willcreate it again when you delete another file or folder) so now delete it 3- find this archive "autorun.inf" and delete it, you can change theext by .txt to see what is inside, it's contain this information: [autorun]
;ibiblmjgamvmodocwzjkostqzppssmxcplaynwlzhplnesfcvqiadihctztr
shellexecute="RECYCLER\S-7-6-80-100015368-100013452-100001365-7286.com c:\"
;bgbwilfidaalxblibzdnkwlfwvnqapgqvqlcmvfvlwudeuzhkwardzyiibhmqvdcolhjqmfamdoeeepvmnhertksxrbkyergal
shell\Open\command="RECYCLER\S-7-6-80-100015368-100013452-100001365-7286.com c:\"
;khbspqdveitzhbftkujolleshraaqinbizeahivqavweucwcigvjltmpnjdxpcbfdwzsbcdjyxjpitmizduaxbpltzcpycjpacgpzivjp
shell=Open4- Restart your computer and you're done
If your pc run in same do next
download
http://www.quickheal.co.in/downloads.asp
After instgall the quick hill, restart and scan
Dec 10, 2010 | Computers & Internet
How to remove autorun.inf, system volume information, recycler etc virus from the harddisk.
1st: Go to Tools>Folder Options>View>unckeck this items below:
1>display the contets of system folders
2>hide extensions for known file types
3>hide protected operating system files(Recomended)
2nd:check all other options in VIEW
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:,D:,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
continue this proccess for all drives where you can see RYCLER folder
NOTE ADDED: This site is listed by McAfee Site Advisor as a potential source of adware and malware.
another answer::::::::::::::::::::::::
Use a batch file (Example.bat) to change it from to a non hidden and a non read only file. It will convert it to a deletable folder and delete it. Do not delete the Autorun file because I found that the virus changed one of my documents to the autorun.
@Echo off
ATTRIB -S -A -H -R
Pause
Then if no errors come up after running the batch right click on RECYCLER folder and click delete.
Make sure the Batch is in the drive not the subdirectry.
(Example) - DriveLeter>Example.bat
Hope this helps : )
Please note that the following advice if taken will absolve me from any responsibility. I am only reporting what I did to get rid of the virus installed on my hard drive.
1. You should be able to see your root drive root drive which is c: or d: etc.
2. Ensure that you are able to see hidden files by going to Tool>Folder Option>view and checking off hidden files.
3. System Volume Information and Recycler should be visible in your root drive (c: d: or whatever drive you use)
4. Right Click on Recycler folder and go to Properties.
5. Go to the tab labeled Security, If your user name is not there then add your username that you use for XP . Give yourself all security rights as well as the SYSTEM user. Then press okay. If you cannot see the security tab and you are using XP professional then go to Tool>Folder Option>View uncheck box "Use simple File sharing" then select Apply.
6. Right Click on System volume information folder and go to Properties. Repeat step 5.
7. Go to the garbage icon on the desktop and right click. Choose properties then check the box " Do not move files to the recycle bin. Remove files immediately when deleted." Press Apply.
8. Go back to the root drive and delete Recycler folder.
9. Go to the System Information folder and delete the last folder. These folders are where Xp has taken a snapshot of your system in order to restore it. The virus is hiding here in the event that you restore it is also restored.
10. You should now open the registry editor and remove the virus from here so that when you restart the virus is not recreated.
11. Open the registry editor. Start >Run> then type regedit in the box and select OK The registry will now open.
12. Hit Ctrl+F Type Recycler in the search box . Delete the entry when found. press F3 to find the next occurrance of Recycler and delete.
13. Close regedit.
14. Go to all installed harddrives and so steps 2- steps 6, steps 8 and steps 9.
15. Run your virus software. You should be able to update any virus software that was previously unupdatable.
16. Reboot your computer
17. Verify that that the reycler folder is deleted from you root drive.
18. Then you can uncheck the box in the garbage that you checked in step 7. To keep all you deleted files in case you need to restore a file that was accidentally deleted.
My findings: This virus is recreated using the methods of the garbage bin. Everytime you delete a file it recreates itself because it looks in the garbage and restores or copies the virus information inside. If the virus is not able to be stored inside and is immediately removed when you check the box in step 7. Then it cannot recreate itself and all of its power is lost. So erasing it from the registry and drive ensures that it cannot return.
I frequently get this headache and finally heartache sooo annoying it had brought too much trouble for me. After installing various kinds of software, running them and so on, I found some of them useful and some of them not at all effective.
Even if we make changes in folder options to view all the files and change various settings, searching through regedit etc or following by some software, in most conditions a typical average user lands in confusion and finally some disaster happens to his system.
I found this simple system to effectively remove Recycler virus - Blam to Recycler virus.
1. Go to Desktop, right click on Recycle bin and select properties.
2. Check (select or put a tick mark) on the square box (Do not move files to the recycle bin. Remove files immediately when deleted)
3. Get File zilla FTP which is free and install. (you dont need to change any file settings)
4. without entering any sort of web address anywhere click the directories in the Local site box.
5. Then each directory will display all the folders below this box with file name, file size, file type and last modified.
6. Now check if RECYCLER folder is there. Then simply delete it.
7. Your job is done.
8. Repeat in all the folders by searching if it is sub folders too.
9. Repeat for each directory ( C D E F ...)
After your job is done again go to desktop, right click on recycle bin and then deselect on the square box.
Apr 21, 2010 | HP Computers & Internet
I want to remove autorun.inf from my pc......plz tell me how
what kind of autorun.inf???
a virus or an application that are automatically runs in start up??
like yahoo,skype,nero,antivirus,printer,etc..
pls state it..
if virus you can try to run an anti-virus software... bt im guessing that you have a recycler virus...as my experience i've tried almost all anti virus software to remove it, but i always fail..i recommend format is better action...
Feb 25, 2010 | Office Equipment & Supplies
Is recycler a virus.
Yes it is a virus
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:\,D:\,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
Jan 14, 2010 | Computers & Internet
Delete autorun.inf and that reappears. there also a folder called recycler that also reappears....
the folder named recycler is harmless..but the file autorun.inf is parasite..we can remove that using a software named "autorun eater"
and it is available free
http://www.softpedia.com/progDownload/Autorun-Eater-Download-85585.html
Jan 02, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Worm.win32.autorun.blw virus appear in my system i already use kesper sky, but not solved. please advise a solution. thanx
When the executable is run on the victim's machine, the worm copies itself to the following locations:
  • %Application Data%\remove.exe (Copy of itself)
  • %Application Data%\autorun.inf
Where %Application Data% = c:\Documents and Settings\All Users\Application Data
Autorun.inf has following command
Exp: [autorun]
shellExecute=remove.exe
The worm adds a Run entry in registry so that it executes itself at every startup:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    "(Default)" = "%Application Data%\remove.exe"
Symptoms -
  • Presence of above mentioned files.
  • Presence of registry entries mentioned above.
Method of Infection Method of Infection - This worm spreads by using autorun.inf on shared drives and removable devices.
Removal - A combination of the latest DATs and the Engine will be able to detect and remove this threat. AVERT recommends users not to trust seemingly familiar or safe file icons, particularly when received via P2P clients, IRC, email or other media where users can share files.
Thanks for using fixya..
Sep 14, 2009 | Computers & Internet
AUTORUN.EXE & RECYCLE VIRUS
You need to do a low level format on the pen drive and the system drive. I have found by using programs like kill disk is the best way to get rid of a worm virus. A regurlar format will not work, unlike what they say to you. Kill disk will stop all running prorgrams on the drive. What it does it rights zero to the pen the drive. After that you need to do the same to your system drive. Otherwise you will be back to square one.
Aug 09, 2009 | Computers & Internet
I have a recycle virus suggest me removal tool pls
Dear user,
pl search in google for autorun eater2.3
and download it it will remove autorun.inf virus successfully
Regards,
Ravindra Shah
Jun 06, 2009 | Computers & Internet
My hard drive partitions do not open . They show access denied. There is an autoplay choice also, which, when clicked, shows Recycler/S-5-7-99-100024702-10005766-100009752-4570.com , not found.
hi
this is because u have removed a virus but not removed a autorun.inf file which is associated with the virus.
to remove the inf file follow these steps
start -->run--> type CMD click ok
in command prompt
d: (enter)
attrib -s-r-h autorun.inf (enter)
del autorun.inf
do the above to all drives and restart the system thats all
Apr 07, 2009 | ASUS P5GZ-MX Motherboard
RECYCLER FOLDER Virus or Malware in all drives.
If you remember when you got this virus or whatever it is. Try to restore to an earlier date, by going to Start, Programs, Accessories, System Tools, and System Restore. Choose roll back to eariler date and pick a date.
Mar 15, 2009 | Altec Lansing ADA995 Speaker
Computers & Internet Logo
543 people viewed this question
David Payne
David Payne
