Procedure and tools needed
OK, you must remove the front axle assembly to access the axle flange and then the seal, follow the instructions at the link but once the axle is out remove the axle flange from the front diff and replace the axle seal, use a seal driver and lube the new seal with lithium grease (white grease). You will need an air impact to get the flange nut off, replace it with a new one (do not reuse) and do not over tighten it. Cinch it down and then go about 1/8 more of full nut rotation to preload carrier bearing setting then spike in place. Ford F150 Front Axle Replacement Part 1
SOURCE: 2005 Yukon Front Diff Axle seals
You don't have to remove the whole diff to change the seals, but you will have to seperate it where the shaft meets the carrier housing. There is a clip holding the passenger axle shaft in place that you have to remove to change the seal. The drivers side axle stub can be removed with a little force as there is a spring clip holding that side in.
SOURCE: left front axle seal
This is a fairly involved job. You will have to remove the brake assy, then seperate the ball joint and remove the axle assy. You will need a seal puller to remove the axle seal (At trans I assume) and a seal driver or something flat to install the seal. You will also need a 32mm socket ( if my memory is correct ) for the axle nut and a torx or hex socket for the brake caliper and a splitting fork for the balljoint. Be sure to tourque the axle nut to spec when reinstalling or you will be replacing a wheel bearing next. Hope this helps...Good Luck.
SOURCE: Left rear axle seal is leaking differental oil.
ok then here is the procedure
1 take off the axle nut
2 on the lower control arm you will find a large nut and bolt i belive the nut is a 21mm and the bolt side is an 18mm. this bolt is the one at the knuckle near the brakes. remove it
3 you will need to pull the knuckle out of the way or a helper to pull the knuckle out of the way so you can slip the axle out of the knuckle.( its a tight fit but there is room to slip it out.)
4 use a pry bar to pop the axle free of the diff. hosing its held in by a spring clip make sure the clip comes out with the axle if it gets stuck inside you will have to fish it out.
5 use a pry bar or screwdriver to pry seal out of housing then use a flat object that contacts the entire rim of the new seal so it can evenly be installed with out getting smashed and tap it in with a hammer. ( a good trick here is to use some grease and pack it into the new seal where the spring is this will prevent the spring from being shocked out of the seal during instalation . the spring keeps tension on the rubber in the seal so it stays tight to the shaft it is sealing.)
6 then revers the above steps. also make sure you are using the right gear lube it will most likely be 75w-140 but make sure you check your owners manual will tell you if it doesnt say on the diff cover. you can cause a lot of damage if you put in the wrong thing. and make sure you feel the axle spring clip snap into place.
as a note there are two types of axle seals that are used on these so if the new seal looks different than the old seal then the folliowing will be important to you.the seals on these have been redesigned so if you axle has what looks like a cup or dust cover pressed onto the shaft where it goes into the diff the new style does not use this and it will prevent the axle form going in all the way so the spring clip will not lock in and you will have a leak. so you will have to remove it and install the axle without it.
SOURCE: 85 cj7 rear axle removal
Do you have bolt in axels? or are they held in with C- clips? If its bolt in axels you need to remove the bolts, and you may need an axel puller to get them out. If its got C- clips rear cover on rearend has to come off, and pin has to be removed to get C- clip out to get axel out.
SOURCE: front pass side cv axle removal on 2003 hyundai santa fe
pull swiftly !!! on the axle hub
as its got a big circlip in there & that is why it feels STUCK!
Cheers Rob
