Konica/Minolta Magicolor 2490mf Printer won't come to rewady mode. No service errors indicated. Display says warming up then message goes out but print key light is stil red and won't print at all. Can Scan and Send fax but won't print incomming faxes.
  • 2 more comments
  • bwm1256 Jul 17, 2009
    Tried nvram reset to no avail.
    Printer is out of warranty. we sold it. we are trained and authorized . I kind of feel that there is an interface problem, but it also may be leaning towards a fuser problem. I have seen this on other older models. Looking for troubleshooting ideas.
    thanks.
    p.s.: Factory tech support was not too much help.
    No, the display stays lit, the message "warming up" just goes off and the display is seeming as if the printer is at ready temperature; but the print key indicator is still red and nothing will print at all.
    are the steps listed in the service manual? maybe you should give them to me anyway. also, we've done some resets but maybe you could expound on what you mean by resetting the printer through the display.
    Bert
  • 4,472 Answers
First off how old is the printer? If it is still under manufacturer warrant you will want to have it serviced that way. Also when did this start and how much use has the printer recieved. Once I have more information I can assist you further. Please don't request more assistance until I get a chance to properly assist you.
Thanks,
Lee
Posted on Jul 17, 2009
  • 1 more comment
  • Lee A.
    Lee A. Jul 17, 2009
    So just to make clear the issue. It will say warming up then the display goes out totally and displays nothing? Also have you performed all the cleaning maintenance? Are you able to reset the printer through the display.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 17, 2009
    Have you tried performing all the cleaning maintenance? Also did you try and reset the printer through the display? If you need the steps I can give them to you as well.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 17, 2009
    http://bsnl.konicaminolta.nl/data/handle...
    The steps for cleaning the unit are on p.136
    The reset should be the first option in the menu select. refer to p.21 for those instructions.
    Thank you,
    Lee
  • 19,396 Answers
Try leaving the printer overnight.
You can also reset the NVram.
On other models you access the service menu turning machine on while pushing and holding the TWO up/down menu buttons at same time. Access nvram menu Then find the Reset option.
I am not sure about the procedure, I do not have service manual for this model.
If I find a service manual I will post here.
If no fault is detected it can be a faulty main control board, or even the board that controls the fuser or some other part failing erratically.
You may need a technician on site to fix the problem.
Here the part list.
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
I neede the driver for Konica Minolta MAgicolor 2490MF,
1st You download Printer Driver. Free Konica Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 18, 2010 | Konica Minolta magicolor 2490MF Laser...
Konica minolta 2490mf
18H: Heating roller warm-up failure
1 Check the fusing unit for correct installation (whether it is secured in position).
2 Check the fusing unit, DCPU1, and PRCB for proper connection and correct as necessary.
3 Check the lever of the safety switch and correct as necessary.
4 Change the fusing unit.
5 Change PRCB.
6 Change DCPU1.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Feb 18, 2009 | Konica Minolta magicolor 2490MF Laser...
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Aug 11, 2008 | Konica Minolta magicolor 2490MF Laser...
52 people viewed this question
k24674
