Question about Sony NWZ-E436F MP3 Player
Battery dead unless pluged into computer. Charges
Battery dead unless pluged into computer. Charges for 2 days. when disconnected, player will not turn on
  • 530 Answers
Friend, the power switch is damage thats why the charger acted as switch. replace the power switch
Posted on Jul 17, 2009
It is not a dead battery , the problem is you have let the battery run to low on too many occasions, the real problem is the battery now has a memory point it only charges to a minimum level.
Without the USB cable connected take a clothes peg or any spring clip and put it on your media players play button to make it stay on and the unit will display the low battery warning,the whole time the play button being held down, leave on until the battery is truly dead and won't turn on again.
Reconnect to USB cable it may take several attemps when you see it start charging, do not disconnect it again, let it charge for two hours minimum.
Posted on Sep 03, 2009
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Ipod only works when connected to computer, once i disconnect immediately turns off. whats could be the problem?
When the IPod is connected to the computer, it also charges the battery.
Leave the IPod connected to the computer for several hours so it can charge the IPod's battery.
When you disconnect the IPod after several hours and it still turns off, then the IPod's battery is dead and needs to be replaced.
Sep 19, 2010 | Apple iPod nano 3rd Generation
The battery full charge only reach 98% & says pluged not charging!!!what this mean?
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
May 17, 2010 | Computers & Internet
Charges, plays on docking station,but doesn't play when removed.
try doing a firmware update when you plug it into your computer, there should be an option in iTunes in the My iPod section to check for new firmware.
Mar 08, 2010 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod touch wont turn on unless pluged into computer
Itmaybe a battery problem...if you think its not a battery problem,you may want to try a software upgrade/restore...if your software version is already the latest one,backup all the ipod contents before you restore...you will find the restore option in the summary tab in itunes.
Sep 27, 2009 | Apple iPod nano
Sansa crashed have white screen
I have a e250 also and it white screened. I could'nt shut it off. I just left it on overnight and 1/2 of the next day until the battery went dead. Then pluged it in. It Worked!!!!
Jan 19, 2009 | SanDisk Sansa e250 MP3 Player
When i shut down the com. my zen wont start up anymore
When you let the battery totally run down on these, it has to sit and charge, looking quite dead, for a little while before it has enough of a charge to boot-up again.
Dec 28, 2008 | Creative Labs ZEN Vision:M Digital Media...
I hav a phone problem and a samsung 1gb mp3 player
both of your device have some hardware problem send it to service center for details checking.
Jun 20, 2008 | Nokia 6600
My Sansa e260 4gb player wont turn on at all nothing is happening with the blue ring or when pluged in to the computer it just stopped working after I pluged into the computer to charge
It's dead. Throw it out and buy an i-pod. My e280 did the
same thing. One day: fine, the next day: Blue Ring of Death.
I have tried everything on the internet, even downloaded Ubuntu and typed in all the e200tool Nuclearscriping BOARDSUPPORTSD and Manufacturing Mode commands. Nothing. It's dead 2months out of warranty. Piece of %$#@!!
Jun 02, 2008 | Audio Players & Recorders
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
hii
just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
let me know what happnes..
tc
May 28, 2008 | SanDisk Sansa MP3 Player
Sony NWZ-E436F MP3 Player Logo
412 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
